Tail, Signal and Brake loght wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-18-2012, 09:31 PM
Babyburr's Avatar
Okay, here is what I have and I think I need a little assist in wiring these tail lights. Lights are leds and have 4 wires. Ground, turn, brake, tail. My wiring harness only has turn, tail, and ground. My turn signals go through the stop light switch, which, when turns are on, it magically overrides brake light and flashes on that side.
I know ground goes to ground, turn goes to turn, and tail goes to tail, but, what do I do with the brake wire from the tail light assembly?? Just not use it, or splice in with turn???
Thanks, guys
Old 08-19-2012, 04:41 PM
MRTS33's Avatar
33 Pontiac 3W Sport Coupe
Some systems have seprate brake and turn lights. I'd play with it and find the look your looking for. Putting the the 2 wires together and connecting to your single stop/turn wire won't hurt anything in my opinon.
Old 08-19-2012, 07:05 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
See attached schematic for turn, brake, taillight wiring.
The brake light circuit goes to the turn signal switch. This is what your harness has.
If you can add another wire directly from the brake light switch to the LED assembly, the brake lights will work even when the turn signals are on.
vicrod
Old 08-20-2012, 11:32 AM
Babyburr's Avatar
Alright. Thanks, guys for the assist
Old 08-20-2012, 12:11 PM
ogre's Avatar
the 'Duracell Project'
2 choices:
tie the stop and turn together will give you brighter stop lights
or if you have a separate 3rd brake light circuit in your harness use that for the brake circuit. youd still have the brake light function through your turn signals too.
i'd try the second idea to see if it works right and give sufficient turn signal lights
Brake/Tail Light wiring 1F9O4R7D Electrical 16 08-24-2010 12:50 PM
Rear brake light/turn signal problem new wiring. bobwire Electrical 3 12-13-2009 04:57 PM
brake light and turn signal wiring slammed 57 Electrical 4 10-28-2009 06:25 PM
79 TA: hazard, right turn signal, brake signal out Gladis Electrical 6 12-25-2007 10:06 PM
brake light, turn signal, tail lamp problem worknprogress72 Electrical 6 01-06-2006 12:20 AM
