tailgate replacement help needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-19-2005, 04:44 PM
brian12c's Avatar
so theres a huge dent in the tailgate of my 95 dakota and ive found a new tailgate for it but theres no handle or latches or hardware inside so I would have to use the stuff from the old one. how hard is transferring and install ing all that to a new tailgate?
Old 11-19-2005, 06:31 PM
Wiki Edits: 31
it is very easy, start taking the dented 1 apart and take pics, put new gate togther using parts and pics. if there is an access door on the inside, it makes it very easy.
Old 11-20-2005, 11:33 AM
Tazz
If it was a Ford...
I'd tell ya to drill out the rivets and order replacement rivets and go to town disassembling the old tail gate. Take pictures if it will help you remember what went where. Any adjustments should be on the body so you should be good to just reassemble it and install it.
Tazz
metalshaping and panel replacement '40 Willys roof Randy Ferguson Body - Exterior 18 11-26-2005 09:00 PM
advice needed for hinge pin replacement Neophyte Body - Exterior 1 10-23-2005 06:00 AM
what size rim, slick width and backspacing are needed? sb72elcamino350 Transmission - Rearend 3 06-22-2004 04:16 AM
Part 2--Metalshaping/Panel Replacement '34 Chrysler fender Randy Ferguson Body - Exterior 1 06-03-2004 07:27 PM
33 truck tailgate hinges hot 33 Body - Exterior 1 10-17-2003 05:02 PM
