Tailight faliure blown fuses - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-29-2005, 11:27 PM
5.0Falcon's Avatar
WHY NOT?
Hey so i have had this problem with my pickup for a month now that i have been troubleshooting and had completly forgot about bring it up here so i hope someone here can shed some light on my lighting problem
Specs-
'85 Chevy S-10 4x4 tahoe EXT CAB 5SPD 2.8L
For some reason the tailights and running lights on my Pickup stoped working. (headlights still work) The fuse would blow on the tailight/courtesy lights. So i assumed a short but none could be found in the wiring going to the chassis, and i eliminated the tailights themselves when i disconnected the connection befor the lights and they still blew.
So i replace the light switch because a section on it looked burnt. No solution.
and just resently the turnsignals stoped working too.
I installed an aftermarket Pioneer stereo in my truck and was their a while befor the problem started so i assume it was not that. it was intalled into the stock wiring.
I think i mentioned everything.
Oh one more there is glitter next to a box that the wiring to the tailight lead from and this is on the firewall. (dont ask about the glitter please it was a prom joke)
Old 06-30-2005, 02:42 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
disconnect the wires to the column see if it still blows
the head light work off a different system than others
it doesn't have a fuse
sr66
"SlowRide66"
"Illegitimis non carborundum"
Old 07-01-2005, 11:29 PM
5.0Falcon's Avatar
WHY NOT?
huh alrighty ill give that a try that will eliminate the turn signal switch right? because they are two different switches
Old 07-02-2005, 12:23 AM
Rob Keller's Avatar
Wiki Edits: 38
that will eliminate the turn single and 4 way flasher
if that dont work then the brake light switch
there is a lot of different systems that all come together in the lights its complex but not to bad once you figure it out
in a nut shell
head light is its own sys
parking lights
brake lights
turn singles
all run together but are there own systems
did i make it better or worse??
sr66
"SlowRide66"
Old 07-02-2005, 10:14 PM
docvette's Avatar
Wiki Edits: 12
Truck lights
Doc here,
First off, Does your Truck have trailer lights? If so DISCONNECT them and refuse and retest.
The MOST common cause of rear light shortage on trucks is the utility plug under the rear bumper..or at the hitch, Gets full of water, mud and other wildlife..
That being done, and results negative, than determine if your turn-signals SHARE bulbs with the tail lamps or the brake lamps..(Sorry, Do not have a diagram...so you'll have to get one...)
If it shares with the Tail/Running lamps, than that circuit will run through the steering column to isolate directional activity..(I.E you can't have both tails hooked in parallel and expect only one light to flash on an incandescent bulb, just ain't happenin'...without opening one output)
Same is true IF it shares with the brake lights...(and the most common design because it is a brighter filament)
Check to BE sure you have the proper bulbs in the PROPER sockets..a single filament bulb installed in a duel filament socket will short the two circuits together...
If all that checks ok..pull the plug at the bottom of the column, determine what are turn-signals and what are tails, brakes and inputs, check those for a dead short to ground..
Hand over hand the harness to the rear to be sure nothing is cutting or chafing the harness...
Your circuit breaker for the headlights is usually located inside the headlight switch, but since you say it works OK, then your probably fine with that...
Another thing that will cause similar problem is if you mistakenly hooked the CD memory or power line up to the dim circuit in the harness and the CD fuse blew..To check, just simply unplug the CD , refuse and test the lights...
Try those, we'll go from there..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 07-03-2005, 01:39 AM
Rob Keller's Avatar
Wiki Edits: 38
i have not been here for very long but one thing you can count on is a excellent description/diagnosis from
Doc Vett
Doc.. you seem to be a walking, talking encyclopedia
how do ya do it??
thanks for all the great knowledge
this sign definitely dose NOT apply to you !(see pic)
rob
sr66
Name:	slowrides pictures net 081.jpg
"SlowRide66"
All Roots Blown Cars Here Please!!!! AFBCamaro Engine 5 06-21-2009 08:53 AM
TCI Stall Converter - Blown SB 68NovaSS Transmission - Rearend 10 09-09-2008 01:42 PM
1995 Mustang fuses ArmyofOne Electrical 2 09-23-2004 12:52 AM
running w/ no fuses 65truck Electrical 16 04-04-2004 10:26 PM
Virginia Drivers of Blown Cars Flywhel Hotrodding Basics 0 01-12-2004 12:28 PM
