Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Taillights/Turn Signals
Old 08-02-2004, 10:05 PM
60convert 60convert is offline
diodes
if you wire it up so that boththe brake and the blinkers have a diode inline with them you will be able to use the same bulb you will need 4 diodes for the rear one from each wire spliced inline with each blinker and each brake lamp going to the bulb.
Jesse
