Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Taillights/Turn Signals
Old 08-31-2004, 07:36 PM
66Rat 66Rat is offline
I may be wrong, but you should have everything you need in the wiring harness, the way it is. Most cars, up until the late eighties only had two bulbs, or one dual filament bulb. The same filament is used for both brake and turn signals. For example, on a chevrolet, their is a wire that works the taillights, one that works the left turn/left brake and one for the right turn/right brake. You only need more bulbs if you want an amber turn signal, like the new cars have.
