Tailpipe Angle vs Interior Resonance - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-28-2006, 03:25 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
I was thinking today, does the angle of the tailpipe (or exhaust tip) outlet have an effect on interior resonance/drone? I'm not sure if I want the exhaust on my Jeep to exit
straight out-
angled down w/straight cut (about 45')
straight down (the 45' turndown with a slash/baloney cut, rather than straight across)
Old 11-28-2006, 03:28 PM
Wiki Edits: 7
see pic...
straight
45' straight
45' slash/balonga cut parralel to ground.
Name:	tail pypes.JPG
Old 11-29-2006, 10:19 AM
hotrodf1's Avatar
Chasing dreams with a ball bat
I think typically the more the exhaust is aimed at the ground the more resonance you would get. The noise bounces off the pavement more.
And of course exhaust exiting under the car with turndowns is about the loudest (interior resonance) of all. But it does sound good that way.
Old 11-29-2006, 10:30 AM
I doubt you'd notice much difference except with the turned end pipe if pointed to the ground would stir up a lot of of dust and dirt rolling across a parking lot or dirt road or field.
Pinion Angles and Driveline Setup for the Street Centerline Suspension - Brakes - Steering 39 03-29-2015 09:02 PM
1986 or somewhere around there s10 driveshaft angle problems fumplet Transmission - Rearend 10 01-16-2006 09:20 PM
notching tubing benchracer1 General Rodding Tech 16 04-12-2005 11:02 PM
angle plug heads and s-10 mychevystang Engine 7 03-21-2005 02:37 AM
maximum 9" offset angle cboy Transmission - Rearend 1 11-28-2004 03:46 PM
