-   -   Which tailshaft needed for Turbo 400 to VY IRS (http://www.hotrodders.com/forum/tailshaft-needed-turbo-400-vy-irs-222035.html)
the creeper 07-23-2012 01:32 AM
what tailshaft would i use to hook up a t400 to vy commodore independant rear suspention;its for a WB 1 tonner:confused:
Arancio400 07-23-2012 07:30 AM
creeper, you do realise this forum is based in USA? Most on here wont know what a vy, or wb or commodore is for that matter!!
Have you been on aussiev8?
Are you going to run a vy independant diff in a 1 tonner?
Cheers
Karl
mmerlinn 07-23-2012 10:42 AM
The length of the tailshaft is going to depend on the length of the tail housing or the adapter housing that you are using. What is the length of the housing you want to use with the tailshaft?
the creeper 07-23-2012 10:04 PM
I do relise thaty karl
Cheers
Karl
No mate ill try Aussie v8 but i knew id get someone like you to help mate.Yes im going to give it a go .:eek:do you think ill have many problems?
the creeper 07-23-2012 10:16 PM
Lengths
wow ive got some homework to do .:embarrass
Arancio400 07-24-2012 06:11 AM
I guess it depends if its going to be road reg? They use to do jag irs into vans and stuff back in the day so I cant see it being impossible but would be pretty hard to get rego I would of thought.
I havent heard of any that have been done but if they can do 4 link setups and get them passed(not in wa) then I guess your in with a chance!!
