tailshaft trans keeps leaking - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-07-2004, 04:46 PM
Hello, I have just replace my tailshaft seal in the 700r4 trans in my 86 s-10, for the second time. what would cause the thing to keep leaking? Not sure if my unknown vibration would be causing that or not. I know driveshaft yoke doesnt seem to move toom much when I wiggle it up and down
Forgot to add that I used emry cloth to polish driveshaft yoke. I also put this seal in with an old bearing outer race
Old 01-07-2004, 05:37 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Re: tailshaft trans keeps leaking
You have to have the rear wheels off the ground and tranny in neutral to check for slop.
I would say that you need to change the bushing in the tail housing.
Old 01-07-2004, 05:41 PM
I'm with Bestmech. This time replace the bushing and the seal. Then check the slop in the yoke. Should be tightened up. I would check it again in about 3 months to see if you treated the symptons instead of the cause.
Trees
Old 01-07-2004, 05:55 PM
Crazy Mopar Guy's Avatar
I think many will take the bet that your vibration is what is taking out your seal.
U joints, driveshaft angles, physical damage on the driveshaft, I would even look to see the rear u-joint is properly seated in the middle of your pinion yoke.
If it's nothing obvious, that tranny will have to be looked at as a possible cause too?
Old 01-08-2004, 05:20 AM
302 Z28's Avatar
As a general rule, you should always replace the tailshaft bushing when doing the seal. That has always eliminated leak problems for me.
Vince
Old 01-08-2004, 09:23 AM
troy-curt's Avatar
Shop Owner And Troll Hunter
Yep, I would say the bushing is worn out.
Troy
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
Old 01-10-2004, 02:26 PM
hello., how much play is acceptable in a yoke bushing?....if that would cause a vibration then tha twould explain why my friends s-10 still leaked cause he had a bad vibration too, but his got worse the faster he drove...2.5 1988 s-10 5 speed.
Old 01-10-2004, 03:55 PM
troy-curt's Avatar
None
Troy
Old 01-10-2004, 06:09 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Come on Troy, you know the correct terminology would be "a split **** hair" at the most is acceptable.
Old 01-10-2004, 11:35 PM
troy-curt's Avatar
Depends on what color it is.
Black would be to much.
Blond would be tight.
Red might do it, hummmmmm........=RCH
Rule of thumb, if it wiggles it's to loose;
Troy
Old 01-10-2004, 11:46 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
A new technical abbreviation?
Yeah I like it!
Why bother using any kind of specs for comparison when you can just say RCH. That would explain red plasti-gage.......I don't even wanna think about the blue let alone how you would wind up with green.
Old 01-11-2004, 07:41 AM
Hello, Just more info here. I did try and move the trans shaft to see how much it would move up and down side to side, when the yoke was out. It moved about 1/2 an inch. How many bearings are in this tranny. Could I possably have more bearings/bushings that are out that would cause this seal/vibration to leak/vibrate?..
Old 01-11-2004, 01:00 PM
troy-curt's Avatar
Crosley is the man you want to talk to now, as you are getting to the inside works of the auto trans, which is out of my knowledge base........HTH
Troy
