tailshaft uni angles - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2012, 01:33 AM
theg's Avatar
Hello to everybody .
Im fitting a 350 chev and turbo 400 into a custom 6 wheeler (picture of the rear axle assembly is in my profile ) Im not driving a front diff (6wd) only the twin rear axles .
My question for discussion is ; The rear diff driven buy the tailshaft from the gearbox is offset by several possibly around 6 inches to one side (ex 4wd) and the rear of the gearbox is centre of car .
Will this cause any problems as I notice virtually all 4wd vehicles have the gearbox flange in line with the diff pinion flange .
Old 03-02-2012, 08:17 PM
rick 427's Avatar
Last journal entry: 33 WILLYS
I kinda remember old Ford,or maybe Dodge, vans had an offset pinion in relation to the rest of the drivetrain....it worked back then...if the rear u-joint isn't in danger of binding, I'm thinking with this build,you have no choice but to go ahead and run it.
frame angles/measurements vistin Hotrodding Basics 6 11-17-2007 11:50 AM
Pinion angles... Canzus Suspension - Brakes - Steering 5 01-05-2005 06:07 PM
How to find pinion angles 53fordguy Transmission - Rearend 3 12-11-2004 05:38 PM
driveshaft angles, what about horizontal angles catscan4free Transmission - Rearend 4 01-26-2004 06:23 PM
is anybody from los angles????? chevyguy75 Hotrodders' Lounge 0 07-24-2002 05:01 PM
