take a stab at engine turning - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-28-2005, 09:05 AM
davedeltadog's Avatar
I work for a company that has a CAD/CAM laser cutter, an endless supply of 304 stainless and a programmer that's a certified motor-head. I needed an instrument panel for my Willys project so I fired off some dimensions to the programmer and a few days later the finished panel showed up at my office. I polished the panel beginning with 180 grit paper and ending with 2000. At this point I felt the panel was a bit mundane and thought engine turning would be cool. I read everything I could find on the internet and went for it. I got some scrap stainless and practiced for several weeks. The real trick is to be consistent with time and pressure applied to create each turn. I made a fixture to give me straight lines and overlapped each turn 1/4" on all four axis using 1/2" wood dowel and 100 grit grinding compound. There are real artist out there doing beautiful work, but I'm happy with my attempt. The great thing is when someone ask me where I got the panel, I can say I made it! Attached are thumbs of the process and finished product. If you get the urge, go for engine turning.
ID:	8673   Click image for larger version
Name:	engne turn 001.jpg
ID:	8674   Click image for larger version
Name:	engne turn 006.jpg
ID:	8675   Click image for larger version
ID:	8676   Click image for larger version
Old 12-28-2005, 09:18 AM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
nice work!!!
SR66
"SlowRide66"
"Illegitimis non carborundum"
ENGINE BALANCING NAIRB Engine 22 01-23-2016 02:44 PM
Build for Hp or Torque? Venturat Engine 76 09-23-2008 11:22 AM
Engine turning Ratchet Interior 9 03-27-2005 08:32 PM
Engine turning aluminum? TwistedDragon General Rodding Tech 6 02-20-2005 06:40 PM
Engine turning over slowly???? lucas_04 Engine 9 11-04-2003 10:51 PM
