TAKE YOUR PICK/ FORD 351w or CHEVY 350 2 bolt main - Hot Rod Forum : Hotrodders Bulletin Board
View Poll Results: Pick between a Fod 351w or Chevy 350 2 bolt main
Ford 351w 18 36.73%
Chevy 350 2 bolt 31 63.27%
Voters: 49. You may not vote on this poll
Old 02-13-2006, 05:16 AM
hey, i just want to see what kind of people we have out there and if anyone thinks like me.
Old 02-13-2006, 08:39 AM
Wiki Edits: 49
Whenever there is a suitable alternative available I will always use it rather than the small block Chevy. As a matter of fact, I would create an alternative before I use a small block Chevy.
Old 02-13-2006, 08:58 AM
Banned
based on the fact aht windsors are more durable ad chevy's are boring- 351. And to think I'm a GM guy.
Old 02-13-2006, 09:33 AM
Im A Chevy guy threw and threw because of the cheap upgrades that can be made and everything around my place is chevys and 350 at that
Old 02-13-2006, 09:34 AM
Windsor....huge bearing surface, well designed oiling + damn near indestructible bottom end. Add a set of decent heads & 350-400 hp without a lot of fuss
They will not rpm (in complete stock form) like a smallblock chevy, but who cares...built right, they are plenty quick, stuff one in a truck & have sufficient grunt to pull anything ya want
Old 02-13-2006, 11:14 AM
Banned
Due to the requirements to upgrade everything on a chevy 350 to prevent them from eating themselves- almost anything else is a pretty good choice.
Old 02-13-2006, 11:22 AM
bigbadbowtie's Avatar
Bottle Fed
I don't know about eating themselves.....
lets see..... GM cast 3.48 stroke crank,production gm 5.7 rods, KB hyper slugs,production 2 bolt main Gm block.... 7000 rpm and is still together as far as I know. It pushed a 3450 lb car to MANY 6.9x 1/8(@101-102) mile passes with the help of a little giggle gas. Figure out the estimate HP numbers(by mph and weight) and you might be shocked.
guess you know what I voted for...
Old 02-13-2006, 02:39 PM
scottford351's Avatar
Stock 351w blocks are capable of 440 cubic inches with off the shelf parts and withstand 750 H.P.
There is no comparison to a 350 chevy.
Old 02-13-2006, 02:48 PM
Re: take-your-pick-ford-351w-chevy-350
Here Here,
I'm with yah. Building a new 23T, just picked up 351W, 4SPD and 9in rearend for it. Gotta stay away from the bowtie and keep it Ford all the way.
Dee.
Old 02-13-2006, 03:22 PM
406 ss monte's Avatar
eat a beaver, save a tree
i like them both, but i like the 350 better. i've had bad luch with windsore's. they don't have enough head to start with.
your going to get all kinds of a$$holes saying ford's suck & chevy suck's. it's just what you like better. if either one was bad they wouldn't have been around as long as they have.
how about a mopar 340 or 360? hands down, mopar out torques them both.
Old 02-13-2006, 06:04 PM
Wiki Edits: 31
I'm a Chevy and a Ford Guy, own 1 of both. I said 351W because they have a few better things than a Chevy, the first reason being the distributor is easy to get to, they can be stroked to a 393 with little trouble and not many peoplr have them, compared to the 350.
Old 02-13-2006, 06:06 PM
67 Deuce 4 Me's Avatar
Bowtie or Die!
Chevy hands down. Relitivley cheap, easy to work on, powerful, tons of new and used parts, Fits into about anything rolling. Unlike the bloated,over rated,over priced, HEMI!
Old 02-13-2006, 06:49 PM
Yawn!!!
Trees
Old 02-13-2006, 07:38 PM
stepside454's Avatar
Originally Posted by trees
Yawn!!!
Trees
Agreed.... well..if I had a Ford...Id pick the 351W...if I needed a small block Chevy, I might pick the 350
Old 02-13-2006, 08:42 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Hmmm sounds like mine, havent turned 7000 but it's been 6500 more than a few times, two bolt main and moves a 4500 lb 4x4 Blazer. Oh yeah, did I mention 9.8:1 compression with a blower??? Going on two months like that. We'll see how long it stays together.
350 chevy help joesnova2 Engine 7 11-08-2009 05:46 AM
Ford Muscle..what's wrong with them? tm454 Hotrodders' Lounge 41 11-20-2006 12:37 PM
engine cooling specs for 350 4 bolt chevy downunder Introduce Yourself 2 10-02-2004 10:41 PM
studed 2 bolt main....strong enough??? chevyelc81 Engine 7 12-05-2002 11:39 AM
ford 302 on chevy 350 mounts topcat662 Engine 1 07-02-2002 11:41 PM
