Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - The tale of the another 350 chevy
Old 08-27-2005, 04:45 PM
rrmccabe's Avatar
rrmccabe rrmccabe is offline
GM Muscle
Originally Posted by zipfactor
yeah it did quit whinning, but i was thinking that maybe it was different when the engine fires, because it spins quicker and may not have enough time to get loose *shrugs*
Nope, I dont think so.
The wire that goes to the "s" (inside small terminal) on the starter. Is it easy to get disconnected while the vehicle is running?
You only have two wires going to the starter? The main battery cable and the smaller one going to the above mentioned terminal.
Keep in mind, you need to get this fixed asap. That starter is NOT going to last long. Don't run the engine long.
Rich
