Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - The tale of the another 350 chevy
Old 08-27-2005, 07:32 PM
zipfactor's Avatar
zipfactor zipfactor is offline
Last journal entry: Just starting
yeah i have the small 12 gauge wire going to the "s" terminal, and the positive battery wire going to the big post on the starter. I'm not sure how whether the distributor wire being hooked up or not affects if the starter keeps spinning, but im not the most knowledgable about car wiring either. What i did the other day was changed some of the underhood wiring. I was checking all my wiring out to make sure it was good (no frayed wires , etc.) and noticed that a wire from the alternator, the sensing wire, was hooked up to a connector. According to the wire diagram i have (out of a haynes manual) it shows that the sensing wire should be hooked up to one of the main feeds to the alternator. So i hooked it up to that. *shrugs* so you dont think its a shimming issue then? thanks for all your responses
