this is regarding my needing to replace a rack and pinion I replaced 2 years ago ,but only 2000 miles or so ago. It is working but leaking bad from the bellows, they were full.
I asked about too much pressure he said maybe? Maybe a bad remanufactured rack? He said I could take the nut off of the back of my pump,and there is a spring inside the supply port that if I cut the spring into a 1/3 that it would reduce the pressure output of my gm pump.
Has anybody else heard or tried this, I did take it apart and i see the spring he is talking about, before i cut it I thought I would check with you marvels here. I have my new rack 74-78 mustang ,my cross member requires me to use this one because i have the 2 holes that go all the way thru using an 8"bolt to mount it .My sales guy at Vic Hubbard speed shop said that the pumps pressure wouldn't have caused the seals to go out,because the seals where it is leaking are under no pressure only returning back to resovoir, I don't know . I will definetly keep my receipt this time they said there is a one year`warrranty on the rack. Anyway wanted to see what you guys thought thanks so much for the input. You guys are the greatest. THANKS JOE
