tall 2'' drop spindles - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-20-2008, 01:12 AM
Sagacious's Avatar
Do you feel like we do?
ive read some articles that show how well the "tall" 2'' drop spindles improve the steering geometry of GM a-bodies by raising the balljoint 1.5''. i have a 73 nova and im wondering if i should just get 2'' lower coils or go with the tall 2'' drop spindes from heidts. any suggestions? im running 17's all around. thanks.
Old 02-20-2008, 01:43 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Stock car products has some online tech that may be helpful to you and if you go to Steve Smith Autosports you can get some software to analyze a front suspension to see just what effect the taller spindles have..Circle trackers do use a taller spindle in some cars to mitigate the design compromises in the stock suspension..
Sam
Old 02-20-2008, 01:44 AM
powerrodsmike's Avatar
Wiki Edits: 161
Dropped spindles will retain your stock geometry. if the taller spindle lowers your roll center, then that's even better.
2" lower could work to lower your car, but they put your suspension at the bottom of the range that it was designed to work .
Later, mikey
BE different....ACT normal.
Early Ford Spindles fitting early Ford axles pasadenahotrod Suspension - Brakes - Steering 3 08-14-2012 07:20 PM
73 nova, tall 2'' drop spindles? Sagacious Suspension - Brakes - Steering 0 02-17-2008 12:38 AM
s-10 & monte carlo drop spindles 406 ss monte Suspension - Brakes - Steering 6 04-09-2004 06:31 AM
Drop Spindles black66 Suspension - Brakes - Steering 1 08-07-2003 04:32 PM
67-72 drop spindles chevyman17 Suspension - Brakes - Steering 2 05-01-2003 05:40 AM
