The meaning of the "tall" deck means the height of the block deck from the crank centerline to the top of the deck where the head bolts to. They are .400 taller and require several special parts that have to be used in conjuction with the block. The pushrods are longer, the distributor is longer, it requires an intake manifold for a tall deck, the headers are going to have to be longer(taller), because they could interfere with the floorpan. The pistons being used will have to be special for the taller compresion height if your using a non-truck 427 piston. Plus, there about 75-100 lbs. heavier than a conventional passenger car block. I've seen many 366 and 427 blocks, and they all had the standard bellcrank pivot ball in the side by the oil filter like the passenger car blocks. Don't know why yours wouldn't. If it has the boss cast into the block for it, then just drill and tap it....
That is odd, all I've seen have the boss. Those tall decks have huge/heavy pistons with 4 rings per piston. Definitely not for performance without upgraded rods and pistons.
This is only one of the many issues and headaches your friend faces with trying to install this engine in his car. Some aftermarket bellhousings have provisions for the bellcrank pivot ball to fit them. Since these engines were only designed to fit into very large trucks, the truck bellhousing would work, but I doubt he would want to put an 800 lb. transmission in his car. I think he should seriously rethink his swap, its only going to get worse. If it still has the truck oil pan on it, it wont clear the front crossmember either, then you'll have to change the oil pump pick-up tube also. Its going to just keep snowballing on him until he reaches a point where he could have had a much better engine for a lot less money. If he is planning on making a street car out of it, all the pulleys will have to be changed to passenger car style and that will include having to change the harmonic balancer as well, because the truck balancer wont accept the passenger car pulleys. There are just so many differences in trying to install this engine in a car, he should make sure the "end justifies the means"....If he is planning any internal engine mods, all the 366 and 427 engines are gear drive and the camshaft rotates backwards compared to traditional camshafts made for timing chains, and wont interchange without have to change the timing set as well....it just never ends.
I had a 427 tall deck in my 57 Chevy,Worked out great for me.
And as you can tell by the marks on the ground,It was a bad A** ride. And them marks was well over 150 feet. ![]() And almost 20'' wide. (each) Last edited by NEW INTERIORS; 02-24-2009 at 12:22 PM. |
Yes it was a automatic. I know it wasn't what you was asking,But I just wanted you to know it can be make into a good motor,Besides what everyone says.
they make a mount for the 502 blocks that mounts to the bellhousing bolts
i think you can get it from scoggin dickey |
here is the link
http://www.sdparts.com/catalog/trans...lBrackets.aspx |
| What to do with BBC 427 Tall Deck? | KNanthrup | Engine | 16 | 07-30-2012 12:27 AM |
| 427 TALL DECK block | icebreakr1969 | Engine | 20 | 10-07-2011 12:01 AM |
| 427 Tall Deck | JJDrifter | Engine | 8 | 08-27-2007 06:15 AM |
| 396 big block and 427 tall deck balance | 85Sierra | Engine | 6 | 11-30-2005 07:02 PM |
| 500 crank in a 427 tall deck? | brian12c | Engine | 3 | 04-25-2005 06:52 PM |
