Tall Valve covers and Finned - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-31-2014, 11:40 PM
Coupedad
I have a couple of questions regarding valve covers for an old school build I'm working on. It's my first build in 50 years, buts it's a car that I wanted since I was a young man.
Q-1) Any recommendations or warnings on finned valve covers.
Q-2) Do I need tall v-cover with 1.6 roller rocker on a set of camel humps (not resurfaced) but the block has been decked.
Q-3) what would be the disadvantage of using a tall valve cover if I don't need it?
Sorry for the elementary question but it's a mid-life crisis for me . My wife may shoot me b-4 I'm done with it. I kind of have o measure twice and cut once. Resources are running out.
By the way- it's a Milner knock off.
Old 06-01-2014, 12:14 AM
ericnova72's Avatar
More for Less Racer
Some short finned covers don't have enough height to clear a roller rocker(typically it is the taller rocker nut that is the problem, not the rocker itself).
You can get aluminum spacers that allow the use of short covers instead of using tall covers
Short covers are going to be more early 1960's correct, especially on a Milner-ish clone, and especially curved end (crowned) finned covers or Corvette finned covers. Both of these will need spacers to clear roller rockers. Some straight end finned covers will clear roller rockers.
Tall covers can be a problem with air conditioning compressors mounting on some applications, and with firewall or brake booster clearance depending on the body style....Tall will also be incorrect for the early 60's look IIRC.
No disadvantage to tall in your case except the era-correct look.
Guess what, an example, here is a tall curved end (crowned) cover I just found that might be right up your alley for the correct look, I didn't realize anybody made them :1958-86 Small Block Chevy Tall Finned Valve Covers - Speedway Motors, America's Oldest Speed Shop.
Totally correct for the Milner look would be a short version of this type of cover on a spacer, if I'm not mistaken, been a while since I saw "Grafitti". You'll have to do your research on that.
Here is a short version, Edelbrock says it will clear roller rockers :Edelbrock 4144 1960-86 Small Block Chevy Finned Valve Covers w/ Holes - Speedway Motors, America's Oldest Speed Shop.
Fin count, oil fill holes or no holes, breathers, that is up to you and how vintage you want to go on the look.
Old 06-01-2014, 12:50 AM
techinspector1's Avatar
Wiki Edits: 326
Eric, I think you nailed it with the Speedway covers. Here's a fair shot of Milner's motor, fairly tall covers, Man-A-Fre 4x2 intake manifold and 4 Rochester two-barrels.....
http://icons.wunderground.com/data/w...y0Byrd/143.jpg
Old 06-02-2014, 07:54 AM
To the OP (original poster):
You have a Man-A-Fre? Pics please! I think "A.G" was supposed to be 1962. My suggestion is to buy some car magazines from 1961-early 62 to get the correct vibe; although that car has been researched to death. Paul LeMat (Milner) is still alive and on the car show circuit; you can usually get him to autograph the car.
One of the things I DON'T like with that car (theres a few)...is the fuel distribution system (specifically the lines). I know that guys did it that way but I'd be afraid of blowing a line off and hosing down my rod with high-octane.
I'd also run more modern brakes; at least a dual master cyl and heavy duty drums/shoes.
Are you using a 283? Milners coupe would have been a 283, although I suppose if he had a friend with GM connections, they could have got a VERY early factory 327 from 'model year' 1963. There were billet stroker cranks back then.
If you're an absolute purist, you will use the road draft tube in the early block, and no breathers; this makes a messy firewall sometimes. If you're an era-correct guy, you can hide a PCV system fairly well and make it look traditionally-oriented.
Old 06-02-2014, 09:43 PM
I got a set of cheap ebay finned valve covers. I'm 95% sure summit, speedway and jegs use the same China made castings only charge more. I have been very happy with the quality. Fit and finish are great on mine. The hardware provided is usable but not high quality.
I don't know of any reason not to use the tall covers, they look better especially when finned.
Old 07-12-2014, 03:49 PM
Last journal entry: New Rev wheels and BFG KDW II tires
Isn't it true that some tall valve covers can cause oiling problems with the rockers?
Old 07-12-2014, 07:46 PM
ericnova72's Avatar
More for Less Racer
How do you figure??
I know some of the early BBC covers had "dripper" tabs over each rocker stud to make splash oil drop down into the rocker ball pivot area, ...but Small Blocks never did as far as I've ever seen.
Old 07-12-2014, 07:55 PM
Something I read. I guess what you read isn't always true. Just thought I would ask the experts here.
Old 07-13-2014, 04:14 AM
Polished aluminum is nice but chrome plated is a lot easier to keep looking good.
Old 07-13-2014, 08:07 PM
1971BB427's Avatar
Yeah, my old Edelbrocks had drippers on the inside for my BBC, but really never figured they were needed since stock covers didn't have them. I found a set of old Mr. Gasket finned aluminum covers for under $50 on Fleabay for the SBC in my Austin gasser, to keep the 60's theme-look. Took some polishing, but I just screwed them down to a bench top, and used my buffer and some polishing compound to bring them back.
They also din't have baffles for the breathers, so I made some from sheet aluminum, and D&T the studs inside, and loctited them on.
Old 07-14-2014, 07:52 PM
Cars, Trucks, Boats
You have a Man-A-Fre? Pics please! I think "A.G" was supposed to be 1962. Are you using a 283? Milners coupe would have been a 283, although I suppose if he had a friend with GM connections, they could have got a VERY early factory 327 from 'model year' 1963.
. I'd just use a 400... looks the same... close enough... LOL! ... 327" started showing up in about July 1961 in '1962' Corvettes... AG movie filmed in 1972 so could have easily been a 400... Movie made on a $777,000 budget... $140,000,000 sales... it was so much like we and George Lucas remembered those days... studio thought it would be a flop...
Old 07-14-2014, 09:19 PM
Cars, Trucks, Boats
Old 07-22-2014, 07:24 AM
QUESTION: wouldnt the manifold work better if the carbs were turned 90*? Fitment not withstanding of course.
Old 07-22-2014, 07:35 AM
Cars, Trucks, Boats
. Probably don't work particularly well no matter how you turn them with siamesed 2" long intake manifold runner lengths... until you get above 9,000 RPMs... Americans would say don't look right turned sideways... Europeans would say look like Webers turned sideways...
Old 07-22-2014, 07:51 AM
1971BB427's Avatar
Since they're open plenum, I doubt it makes much difference which way they're turned. Multiple carbs are always a bit tricky to tune for, and a 4 carb setup requires the linkage to be simultaneous, rather than progressive like some 2-3 carb intakes. The right guy and carb can get them running really well, and make them work even off idle.
Finned Aluminum Valve Covers... pitts64 Engine 1 10-25-2010 08:19 PM
Finned aluminum valve covers k.c. General Rodding Tech 2 08-30-2009 06:32 AM
Painting finned valve covers AntnyL Body - Exterior 11 01-18-2008 10:10 AM
painting finned valve covers - which paint? pcoghlan Engine 5 04-05-2006 10:18 AM
finned valve covers and side plate Dogtack Engine 5 11-14-2002 07:31 AM
