Tank Manifold - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-29-2011, 08:16 PM
Tank Manifold
The tank manifold on the compressor I'm buying goes 3/4 NPT at the tank to 1/2 on the outlet. It houses the pressure gauge and pressure safety pin. Am I being OCD by obsessing over the reduction? My 40' of expensive copper pipe is 3/4 inch....
Old 04-29-2011, 09:17 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
its ok, that way the air will slow down in the piping and help it cool down
i've always made the piping around my separator bigger than the rest of the system
Old 04-30-2011, 07:30 PM
Thanks. I ended up coming out at 1/2" from the manifold and quickly going through a reducer (reversed) to 3/4". By doing that I have my ball valve shutoff, union and flex pipe at 3/4". If I switch to full 3/4" outlet manifold later I only have to replace that short 1/2" segment.
gas tank flikkers General Rodding Tech 2 06-22-2009 08:28 AM
manifold filler neck or expansion tank? lumberjacknooj Engine 6 01-22-2008 05:28 AM
gas tank pletcher General Rodding Tech 1 01-18-2007 08:37 AM
gas tank ryanhill General Rodding Tech 1 11-26-2005 12:01 PM
Need Tank Sender for Custom Gas Tank.... bg Engine 3 11-05-2002 05:13 PM
