Tapping into an existing fuse block - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-31-2010, 04:29 PM
Last journal entry: More information
hey guys,
sooo, on my corvette inspired jaguar xj6, i've completed the job (barring the recent starter issue) -- however, i'd like to officially tap into the wires in my fuse block(s) instead of using the el cheapo "quick splice" devices. I'm wondering what is the best way to do this -- the wires that go to the fuse block are very short -- it is difficult to get in there to splice the wires together. i am tempted to just snip the wires i need, and extend the wire from both ends, and then T-splice into that wire.
i have 5 connections to make -- on a jaguar xj6, there are two fuse blocks. i will need to splice again later on for the radio, but i'll worry about that when the time comes. the connections that i am making are for wires that are hot at position 2 and 3.
my question is, what is the best way to tap into a wire, so that i can heat shrink the resulting joint? all the "western union" butt to butt splices i've made have been very nice and sturdy -- heat-shrunk and tied up. these splices are a bit more of a challenge.
do any of your guys have any tips for how to do this? i was thinking of stripping off some wire, and separating the strands, and then twisting the tapped wire into that, but perhaps there is a more elegant way...
any tips would be much appreciated!
thanks,
tyler w.
Old 03-31-2010, 05:26 PM
Wiki Edits: 31
when I built the wiring harness for the fog lights on my '98 Ford Ranger. I removed about 1/4" of insulation from the wire where I needed to splice into.. slid the shrink tubing down ( 1 size larger than needed for the wire ) the open end of wire. spliced in the wire I needed to splice off of with, twisted it in and soldered it up. then slid the shrink tubing over the wires and shrunk the tubing. works pretty good that way.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Cam Help shsouthard Engine 18 03-29-2009 09:33 PM
hv big block pump for small block roy383ci Engine 9 05-24-2006 06:52 AM
Fuse block diagram crash Electrical 7 04-12-2006 05:42 PM
small block vs big block JUSTINH Engine 28 02-17-2003 04:37 PM
