targetmaster gm block - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-04-2008, 03:52 AM
I have a targetmaster 350 4 bolt main block casting # 10066036. I'm wandering if anyone would know if a early 70's 350 head would work good with this block casting # 3973487X? I still need to get a cam and was wandering if anyone could suggest a good cam for this engine? I'm not looking to build anything to crazy just something for a driver i'm putting it into a 71 camaro but would still like to get a bit of hp out of it. The block looks to be bored 30 over everything looks new in it so i really want to use this engine. thanks
Old 06-04-2008, 07:15 AM
what pistons does it have?
Typically those engines use pistons with 12cc dishes. You will need a set of 64cc heads to make any compression (9.2 to 9.5:1 depending on gasket, deck height, et). With this compression you can run a cam with intake duration in the range of 210 to 220 degrees at 0.050".
Other wise, 76cc heads will get you 8.5:1 cr and will limit the cam intake duration to 195 to 204 degrees at 0.050.
Most 70's cylinder heads will be 76cc. So if you run a stock head then I would just use an edelbrock performer cam (204/214).
I would recommend that you get a set of 180cc darts with 64cc chambers, or get a set of vortec heads, or if you can afford it, get a set of 180cc afr's with 64cc chambers. Power is in the heads. stock 1970 heads suck. You can gain 40 or 50 hp with a set of afr over a stock 70 head even with a mild cam.
If you do get a set of aftermarket heads then get a cam with equal intake and exhaust durations. if you use a stock gm head then use 6 to 10 degree more on the exhaust duration as compared to the intake.
Old 06-04-2008, 10:29 AM
Thanks for all the info i would really like to use these heads since they are totally rebuilt as is the block. Just hoping to get out as much hp as possible but i'm not going to be racing the car and with the price of gas these days i would just like to be able to take it for a cruise once in a while. I will look into the edelbrock cam you suggested. One other question i have a edelbrock torker 2 intake i know these were very popular will this work fine with this set up? thanks
Old 06-04-2008, 01:03 PM
Those old torker intakes kind of suck. I would use a stock gm 4bbl intake before using a torker. The regular edelbrock performer intake should work well with a stock or mild 350.
what carb and ignition are you planning to use?
Old 06-04-2008, 01:40 PM
I dont know what carb or igniton any suggestions? thanks
Old 06-04-2008, 01:46 PM
I would use a hei from summit racing. Get one that has an adjustable vacuum advance canister.
If you want power and mpg, then get a Q-jet. However, these carbs are old and require a good rebuilder for good results.
Want are you doing for exhaust?
Old 06-04-2008, 02:06 PM
What size quadrajet do you suggest? i know a guy that has several probably over a dozen and he is really good at rebuilding them. i was just thinking of getting a set of headers and maybe some aftermarket piping from there or getting a local shop to bend some pipe up for me from headers back.
Old 06-04-2008, 02:37 PM
Headers and some pipe work sound like a good plan. I would also install an X-cross over pipe and use some dynomax super turbo mufflers. Small tube headers would work the best for a mild 350.
Just use a regular Q-jet. They're around 750 cfm. A later model Q-jet would be nicer due to the APT feature. The base plate should be modified to allow for idle mixture adjustment.
Old 06-04-2008, 05:21 PM
the pistons are z8222 i beleive the are made by zoelner or something like that. they look flat and have 4 releif valves on them. yes the block is assembled the stuff looks all new there is no cam yet thats why i asked for advice on what cam to put in. the gears in the car are 3.73's turbo 350 i think the converter is stock it has a b&m shift kit in it. i dont have the torker2 yet a freind has one that i can get cheap but if it wont work good i'll get something else instead. i'm not really concerned about gas milage but on the other hand i dont want anything to crazy either somewhere in between. the heads have new springs, hardened locks, and some machine work was done to them. i'll talk to the guy to see what else was done with the heads.
Old 06-04-2008, 09:29 PM
Thanks for all the info that is very helpfull and yes i do own the heads and i will look for another intake as you suggested. What kind of 305 heads are you talking about i have a set of casting # 14014416 305 heads they are rebuilt new valves 3 angle valve job a guy threw them in with a car i bought for parts a while ago. Someone told me they are useless for a 350 early 80's smogger heads?? thanks for all the help
Old 06-05-2008, 03:54 AM
Great i'm gonna look into that and check out your posts you have on the 305 heads with the 350. Thanks your a great help this chevy stuff is all new to me agian its been about 20 years i've been playing with pontiac only but really like this camaro i picked up. I'll get the valves measured your right someone may have put bigger ones in they are brand new valaves in there.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
GM pressures CorvetteStripes.com over trademark issues Jon Hotrodders' Lounge 11 02-29-2008 04:04 AM
Verify a 351w block. Not2psycho Engine 3 05-27-2007 04:23 PM
4.00 inch stroke crank in a stock gm 400 block sb72elcamino350 Engine 27 12-24-2006 11:17 AM
need info on small block chevys engine-rookie Engine 1 05-03-2003 08:48 PM
