Tarus cooling fan- amp draw? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-17-2009, 10:05 PM
406 bug's Avatar
9.82 @ 139mph
Two questions: I understand that the Taurus/ Lincoln cooling fan has 2 speeds and is a good choice for a reliable high performance fan. does anyone know what the amp draw is on this fan. also I assume this is a puller and I need to convert it to a pusher. Would I just reverse the leads and flip the blade?? Thanks in advance for any help. Ken
Old 01-17-2009, 10:43 PM
Rustydawg's Avatar
Cruzin w/Elvis in Bigfoots UFO
Buddy of mine grabbed a Taurus fan like yours at the wrecker, I think he said it was around 15 Amps load but I don't know if that was low or high speed.
You're looking at 25 or more Amps surge getting that fan spinning up so don't go too small on that fuse / breaker...
Old 01-18-2009, 09:36 AM
If you can keep the fan as a puller. overall it works better that way. Sometimes you can flip the blades over but if can't, you won't get the same air flow running in reverse. The blades are made to move air only one direction. I had to buy new fan blades for my Flex a Lite fan unit when I changed it from pusher to puller. Good Luck
Old 01-18-2009, 09:52 AM
taurus fan
I think the amp draw is more like 30A continuous and upwards of 90A at start-up. It's a popular swap among jeep conversions. I used to have the link bookmarked at pirate4x4.com but if you search taurus fan in the tech pages over there you'll find wiring diagrams and relay requirements for the swap. mudlust.
Old 01-25-2009, 08:59 AM
dklong's Avatar
the maxi fuse for the fan is 50 or 60 amp fuse in the taurus or linc, i think the fan runs a continious 30 amp after start up
building a fan shroud - need help 32Tudor Hotrodding Basics 30 07-03-2008 10:01 PM
EZ-Wire : Fan Connection horvath Electrical 11 03-28-2003 11:35 AM
Radiator cooling fan, relay?, switch? dripcandles Engine 5 03-15-2003 11:37 PM
SBC - effective cooling / electric fan sensor Limey Simon Engine 9 02-06-2003 02:39 PM
Radiator cooling fan?? Dave E Shank Engine 5 10-24-2002 03:37 PM
