Task Force PU on 88 or newer 4x4 chassis?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-02-2009, 10:44 PM
bobinbc's Avatar
Has anyone here ever done this swap? I'm thinking of putting my 57 shortbox on a 95 reg cab shortbox chassis. I know there is a wheelbase difference but I think I know an easy way to fix it. I really like the low look, but the roads around here are AWFUL! Any thoughts are welcome, pics of one on a newer chassis would be great! I know the frame dips down a lot under the cab on these years of trucks, not sure how it would look.....
Old 04-03-2009, 11:30 AM
forestrytodd's Avatar
Official Hotrod Forester
S10 Chasie works much better.
Old 04-03-2009, 01:05 PM
bobinbc's Avatar
I know using S10 for AD trucks (47-55) is pretty popular for the 2wd but I haven't seen a 4wd S10 with a V8 in 55-59. Have you done this?
All the 4x4 55-59's I ve seen are usually done on a 73-87 4x4 chassis, I'd like to try the 88-99 chassis because of the better front end.
Old 04-06-2009, 08:36 AM
I have not done the 4x4 converson, but have done the 2x4. Works OK. I have not done the later full size frame, but have talked with several people who have don it and it is not easy from what I understand, but hey what frame swap is easy!
The V8 issue is not that hard. Just a set of headers for the steering shaft clearance. Look @ summitt for them.
Measure the track widths on the trucks and the wheel base. It is much easier to shorten a frame than it is to narrow one.
Can I use double hump heads on my 88 4x4 sandman_5169 Engine 3 12-14-2008 07:08 AM
newer chassis for 1958 GMC Pickup raginred Suspension - Brakes - Steering 5 10-10-2007 07:34 PM
88 chevy pu tbi troubles bond Introduce Yourself 5 10-17-2004 10:25 PM
Chassis Tuning In The Shop BillyShope Suspension - Brakes - Steering 8 04-29-2004 05:24 AM
88 GMC pu speedometer calabration?? Dave Y. Transmission - Rearend 1 01-21-2003 05:07 PM
