Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Task force Wheel and tire size??
Old 08-23-2012, 10:39 AM
montydofbov montydofbov is offline
Thanks for the info Raven and Dennis.. I really do like the look of 15 inch ralleys and it's going to be a cruiser. I like the idea of getting something that will for sure fit and look good then upgrading later on when the time comes. How's our suspension set up Dennis? Any backspacing required on your rear wheels?
DSRaven; thanks for all the helpful tips regarding the from suspension install. Couple of questions....what are you running in regards to the rear suspension and rear axle? If I understood you correctly, your setup with a 2 degree rake and 2 inch drop spindles required you to c-notch the rear? Did you have to notch the front to clear the rack and pinion?
Thanks for all your input, I'm a newbie when it comes to these things...
