Taurus Brakes Mystery Component... - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-01-2005, 08:30 AM
Being too cheap to have purchased a manual for my used 1993 Taurus GL, 3.8L, 4Dr sedan, I was mystified by the valve mounted above the rear suspension which is connected to some linkage to the rear suspension links. The valve has the brake lines running into it and I can only guess that it does something to the rear brakes when the nose of the car dives down and the rear end rises up during a hard stop. Can someone tell me what the purpose of this valve is? I never had a GM car with such a valve on the rear brakes. The car does have antilock brakes, so this may be one of Ford's antilock brake goodies along with the rest of the apparatus which I fortunately never had to get involved with so far.
Old 06-01-2005, 10:15 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Does it have traction control?
Old 06-01-2005, 10:18 AM
abstruse dutch uncle
You are correct in your guess. It's a load sensing proportioning valve. They are common on trucks and station wagons. When the rear is high up, it cuts more pressure than when it's down. It's not new technology.
It's better IMO than a pressure sensing valve, in that it's 'smart'. You can have larger rear brakes and get the most out of them when you need them. Some Euro cars have a check ball type of prop valve, in which the ball rolls forward to cut pressure when the vehicle is tipped more than a specified angle.
disk brakes conversion no pressure to back brakes shiner Suspension - Brakes - Steering 10 01-24-2011 11:09 AM
Brakes !! NO Brakes !!! Sampson Suspension - Brakes - Steering 9 05-30-2005 08:23 AM
Drum brakes smelling bad nitsud08 Suspension - Brakes - Steering 5 04-11-2005 05:15 AM
63 sub disc brakes or no disc brakes sub63 Suspension - Brakes - Steering 5 03-19-2005 11:31 PM
streetrod brakes bigbadchev Suspension - Brakes - Steering 2 03-10-2004 06:02 AM
