Taurus Hangs Up in Park Position... - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-19-2006, 09:42 AM
On a 1993 Taurus GL, 3.8 liter vehicle, I have recently found that I must take an extra hard tramp on the brake pedal to move the shift selector out of the park position. I don't have a manual on the car but assume that there must be some sort of interlock arrangement which requires compressing the brake pedal sufficiently hard to move the shift lever out of Park. Originally just a light compression of the brake pedal permited the move out of Park.
Any clues that someone can provide relative to the devices and locations of what to check to reduce the amount of pedal force to shift the beast would be gladly appreciated. I occasionally get the impression that I might be stuck in Park for ever but one final and forceful hit of the brake pedal gets the thing out of park. My luck may run out eventually if this condition progresses.
Old 06-19-2006, 10:08 AM
PHATHOM's Avatar
My wife said no more hotrods..
Have someone take a look at your brake lights when you apply the brakes. If they are not operating then your brake light switch is out (also controls the park release solenoid. This switch is cheap and easy to replace (attached under dash and contacts the brake pedal arm.
Old 06-19-2006, 10:51 AM
Thank you for the tip about the brake light switch. That sounds like a good prospect to check out. Since my assistant is out, I'll back up to the barn door and observe the reflection of the brake lights on the door.
awbazar
Welding info Kevin45 Body - Exterior 10 08-26-2011 08:09 AM
E-Town Raceway Park needs your help. coldknock Hotrodders' Lounge 17 07-30-2004 06:15 AM
Double Pole Park Lights horvath Electrical 5 08-14-2003 09:05 PM
Distributor Clock position (long) Screwy Lewy Engine 7 07-16-2003 01:25 AM
Is my Taurus F'ed or what do you think ? pjlavin Transmission - Rearend 5 05-13-2003 12:48 PM
