TBI assistance needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-22-2006, 06:05 PM
Currently have a 91 Chevy truck with a 350 TBI motor that went south. Picked up an older 350 (manufactured in 83-85). Is it possible to use the older motor with the TBI setup so that I do not have to go with a carb and change the wiring harness and such. The older 350 is very clean and had very few hours on it. I do not want to switch to a carb and know I will most likely have to switch to another intake manifold. Will the Holley 300-49 be a possible solution? I would think there is an aftermarket inatke manifold for such a conversion.
I am not a mechanic and was told to bore the holes on the TBI intake out some to allow for the 4 center holes in the TBI intake to fit. I tried this and learned very quickly that this would not work. I had a vacuum leak and had trouble timing the engine. The engine runs and sounds strong but I now know this is not the solution. The older motor is in the truck and I am trying to find someone who has gone through the same thing.
Could my other option be taking the heads off my 91 TBI 350 motor and have them reworked? Would they fit on the older block and could I then use the complete TBI setup? I have been playing with this problem for the last month or so and need some real help. THANKS....
Old 05-22-2006, 06:13 PM
You may be giving up too quick on your base plate modification. I have seen some of these "wallowed out" holes really butchered and were sealed up and made leak proof by filling with lots of RTV before installing bolt with a washer. Don't start it for 24 hours so the glob of RTV has a chance to cure. An alternative before you butchered the base plate was to use the heads off your old motor but it would require the same glob of RTV now.
Trees
Old 05-22-2006, 07:42 PM
dh79's Avatar
There are adapter plates to allow the tbi unit to be bolted to a carb manifold. Summit (and I'm sure jegs too) sells them. That would allow you to bolt the throttle body to the older style manifold but you'll still have to adapt any manifold mounted sensors required for the fuel injection.
81 Grand Prix, 355, 700r4, 8.5" 4.10
64 Oldsmobile Jetstar, all original
Old 05-23-2006, 07:18 PM
TBI Assistance
Trees
I appreciate the feedback. I do not believe the holes have been butchered that badly (if at all). I waited several days after putting on the intake before I put the rest of the TBI setup on and put the motor in. After starting the engine, I sprayed carb cleaner around the walloed out holes to try and locate any leak but could find nothing. I really believe I might have another leak somewhere that I can not find. Since asking last night I have done some additional research where others say what I have done should work. Do you have any further suggestions for me? This is a really nice truck and it is driving me crazy because I am really stuck. Thanks again.......
Old 05-23-2006, 08:24 PM
NorthStar's Avatar
I would swap the late model heads to the early block.
Allows you to use TBI intake manifold, accessory bolts holes will be correct, braces for plug wires have something to bolt onto, centerbolt valve covers can go back on.
Be sure that older motor doesnt have flattop pistons if they are combined with newer heads compression will be too high.
Use the head bolts with 1/2" heads or there might be a exhaust manifold clearance issue.
Be sure to use the correct intake manifold gaskets.
Old 05-24-2006, 10:11 AM
Hippie's Avatar
Last journal entry: HEI comparison.
I second that.
Tbi Mods NAIRB Engine 8 05-03-2005 06:50 AM
TBI "High Idle Problem": conoverbandit Engine 9 02-08-2004 11:49 AM
TBI Questions on a 93' Chevy FS 350 IWANTMOREHP Engine 1 01-04-2004 01:42 PM
350 TBI suggestions needed crshrmn3 Engine 5 12-06-2003 10:28 AM
350 GM Goodwrench Caprice engine in 3rd Gen TBI F-Body? wrmason3 Engine 2 09-14-2002 07:01 PM
