Tbi chevy 350 hesitation. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2010, 12:11 PM
Ive been dealing with a rough running TBI project. Was backfiring and bogging really bad. Finally after a lot of work and help from all of you, Ive got her running good. Starts good, idles good, very snappy throttle. The only thing now is a hesitation when in gear with aggressive throttle. Still seams like a vacuum leak but I cant find any. Could it be a problem with the torque converter. Im running a TH 400. Don't know a ton about Torque Converters but was wondering if a bad one or one with the wrong stall could be causing this.
Thanks
Old 07-22-2010, 12:52 PM
Checked your throttle position sensor volts? It may need adjusted (some are slotted) to give a quicker squirt of fuel (like an accelerator pump).
Old 07-22-2010, 01:44 PM
What should the volt reading be?
Old 07-22-2010, 02:56 PM
what vehicle and engine are you asking about?
Old 07-22-2010, 07:14 PM
The engine is out of A 1990 chevy p/u. its a TBI 350.
Old 07-23-2010, 07:03 AM
tbi bogging
hello,
sorry to jump in on your thread but how did you get it to run better? mine is doing the same thing.
thanx!
Old 07-23-2010, 10:55 PM
I changed almost everything. Tried different throttle bodies, different injectors, ERG valve, new plug wires, new fuel pump, cap, rotor,and distributor. Most of these were extra parts that I had. sure couldnt afford to replace all of that stuff with new. Checked numerous times for vaccum leaks. Every time I changed something it seemed to run a little bit better. I finally found a bad plug even though the plugs were all new. that helped the most but still a little hesitation. You might know this but I put a timing light on each plug wire and point it at my hand and watch for a little bit. you can see if you have a miss in a cylinder this way. It helped me find the bad plug. Anyway hope this helps. Good luck, I feel your pain.You will know the TBI stuff inside and out when your done. Let me know how it turns out.
Old 07-26-2010, 06:21 AM
bogging tbi, egr, cat conv, code 32, etc.
yeah, im getting there. actually replaced the regulator diaphram in the TB this weekend. no different, so i got ticked and took off my catalytic converter, reamed it out, and put it back on. didn't fix the prob, of course, but at least now its got some more pep so i can merge or get out of my dangerous driveway. throwin egr codes now though?! anybody have any ideas about this. i was told obd I systems won't throw codes without a cat. guess that wasn't true.
Great tip about the timing light!
chevy 350 tbi timing?? gofastz Engine 2 04-27-2010 04:58 AM
89 chevy 350 tbi dlsmith1979 Engine 12 10-28-2009 10:25 AM
Ford 351 C vs chevy 350 eric32 Engine 3 09-18-2009 04:42 PM
305 tbi into an older 350? help... NOSBOSS Engine 2 03-23-2004 09:45 PM
89 Chevy P.U. TBI ????? catdad2u Engine 1 11-12-2002 02:52 PM
