tbi chevy motors - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-10-2012, 07:56 PM
larry
tbi chevy motors
does anyone know how big cam you can put in a chevy 5.7 tbi motor with a stock ecm . and it will still run ok... thank you
Old 11-10-2012, 11:27 PM
tbi chevy motors
I know you can't go too much over stock. As long as you stay under 220 duration and 112 LSA or higher you should be ok. If you pick a dual pattern camshaft keep the split small. I would use something like this. Crane Hydraulic Flat Tappet Camshafts 113931 - SummitRacing.com or Isky Hydraulic Flat Tappet Camshafts 201262-27012 - SummitRacing.com
Old 11-11-2012, 05:00 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Some TBI/cam info: TBI CHIPS TRUCK MODS
Unless cost is a factor, rechipping the ECM is no biggie.
Old 11-11-2012, 01:27 PM
larry
tbi motors
thank you . gong to try that if i have to get the ecm re porgramed then i will .... larry
Old 11-11-2012, 01:36 PM
larry
well i got a 470 lift cam ... 225 dr.
366 /427 chevy truck motors badwrench67 Engine 12 01-31-2008 09:24 PM
Chevy truck motors forged???? 76 elco Engine 15 06-29-2007 07:20 PM
on the tbi motors.. can you mod it to use the old HEI distributor ? ghomer Engine 3 12-24-2006 04:14 PM
350 chevy production motors billy65 Engine 0 02-20-2006 11:02 AM
Chevy TPI motors...pros/cons mattmanuel Engine 18 08-22-2005 05:35 PM
