TBI conversion? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-13-2013, 09:49 AM
TBI conversion?
Anyone converted a 283 or 327 eng. to TBI, and if so, what was your results such as do`s and don't`s, problems etc. Thanks for thoughts
Old 10-13-2013, 10:12 AM
Banned
It's the same as converting a 350. I don't know why you would think it's any different? The crank's throw is irrelevant to the installation and the tuning will not be that drastically different. Make sure you have a good handle on tuning though, it makes all the difference.
Old 10-13-2013, 04:46 PM
serious problem
Did I DO SOMETHING WRONG? I have finished my TBI conversion, but my engine was running smooth before, but I have a serious noise coming from what I believe is in the front such as a cam knock. I had a knock that could be heard soft and then hard. I had forgotten to take my fuel pump rod out and started the engine a few times thinking the knock was detonating. But
after I took the pump and rod out I still have the knock, only now it is constant and sounds in the front like cam area. I can put my hand on the thermostat housing and feel the knock. Did I screw something up by not taking out pump rod out before starting up after I put on TBI setup? I have already taken off my intake manifold to see anything odd there, but all looks
ok such as push rods and lifters. Hope someone can help. Thanks
Old 10-13-2013, 04:52 PM
Banned
How does your oil pressure and spark plugs look?
Old 10-13-2013, 05:25 PM
well, I currently only have stock idiot light, and the 2 plugs I took out looked a little dark but not sooted up
Old 10-14-2013, 03:04 PM
Did you remove the fuel pump but leave the push rod in place and did you secure the push rod with a bolt from the frint of the engine as would be typically done when the fuel pump is removed?
Bogie
Old 10-14-2013, 03:19 PM
Banned
2 plugs? its not good for any of them to look different from the rest. Likely an indicator that you're burning oil.
TBI to Carb conversion 4speed501 Engine 3 12-14-2010 08:50 PM
TPI or TBI conversion!? djohnson308 Engine 6 07-08-2010 06:57 PM
TBI conversion problems chevy_c10 Engine 207 05-30-2009 01:59 AM
Just did a TBI conversion and need some advice ghomer Engine 8 12-28-2006 07:16 PM
TBI conversion to Carb Seon Engine 0 10-15-2002 03:20 PM
