TBI fuel delivery problem when starting - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-18-2013, 06:59 PM
LATECH's Avatar
Here is a pinout on the 8 pin HEI/EFI module for TBI setups with small cap dizzy
Fact is stranger than Fiction
  #17 (permalink)
Old 04-18-2013, 07:01 PM
LATECH's Avatar
If this were mine, I would try another Ignition module.
  #18 (permalink)
Old 04-18-2013, 10:18 PM
Wow, that is some pretty heavy advice. I have a grasp of what you guys are telling me, but you certainly have the technology down better than I do. I'll try the test bulb and see if I am getting the signal.
Thanks to everyone for sharing your knowledge and talents. I'll let you know how it turns out.
Fleetsidebob
  #19 (permalink)
Old 04-19-2013, 10:38 AM
I take it that the pick up coil is actually inside the distributor cap and that it is different from the external coil? When you speak of replacing the module, are you talking about the pick up coil?
  #20 (permalink)
Old 04-19-2013, 10:54 AM
Originally Posted by fleetsidebob View Post
When I turn the key to the run position, the fuel pump runs for a couple of seconds and shuts off. I was assuming it stopped running because it was pressured up.
This is normal. In a factory TBI system, there are two separate methods for operating the fuel pump. When you turn the key to START, the ECU closes the fuel pump relay for two seconds to build pressure in the system. This is the only time that the fuel pump relay is used. Once the engine is cranking and builds fuel pressure, a separate circuit closes through the oil pressure switch. This bypasses the relay and keeps the pump running whenever there is oil pressure.
How can I test to see if there is actually pressure at the injectors during start up? I hate to disconnect fuel lines and have gas shooting all over the place.
The only way to test this is to temporarily attach a fuel pressure gauge to the test port on the fuel line to the throttle body. You should see ~15 psi when you turn the key to START. The pressure should remain there the whole time you are cranking the engine. If it drops, you have a problem someplace, like a bad check valve in the pump or a bad pressure regulator.
The pump itself is not very accessable, but I'm wondering if I could use a clamp meter around the power wire to the fuel pump and see if we have current while the starter is turning. Would that make sense?
No. See above. If the problem is a check valve the pump will run but you won't maintain pressure in the system, so an ammeter won't help.
The Following User Says Thank You to joe_padavano For This Useful Post:
fleetsidebob (04-19-2013)
  #21 (permalink)
Old 04-19-2013, 10:55 AM
The pump should run from 10 to 15 seconds. What's going on is a pump shut down by the computer if in that time if the computer doesn't see the RPMs coming up from a sucessful start. Additionally, there is a relay on the firewall that can fail. You need to get a wire diagram to checck all this out. There are minor differences of how this curcuit is layed out that appear year to year, model to model.
If it's a sensing problem often the engine can be started with a prime and it will continue running, if it's a relay problem it will burn the prime then stop running.
You can force the issue by jumpering around the relay but then you've got to be sure that if the key is in run position, the engine better damn well also be actually running.
Bogie
The Following User Says Thank You to oldbogie For This Useful Post:
fuel delivery problem on older 350 chevy SGT@ARMS Engine 6 01-31-2012 09:14 PM
fuel delivery problem with chevy 350 mb1d357 Engine 5 12-01-2008 10:40 PM
fuel delivery problem meev182 Engine 1 03-20-2008 08:25 PM
Fuel delivery problem, anyone knowledgeable on this? PLEASE HELP! dripcandles Engine 7 09-28-2006 11:57 AM
fuel delivery problem has me stumped dripcandles Engine 4 05-16-2006 02:54 PM
