tbi heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-24-2012, 10:22 PM
tbi heads
my tbi heads are center bolt are the roller tip rockers self aligning on these heads like to know if I can use them on my vortec heads I have
Old 12-25-2012, 03:02 PM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
Factory stock TBI heads use self aligning rocker arms.
Factory stock Vortec heads use self aligning rocker arms.
As far as I know GM never used roller rockers on the Gen 1, Gen 2, or Vortec motors.
Make sure you pay attention to pushrod length before you just go swapping roller rockers willy nilly!
Old 12-25-2012, 04:41 PM
the tbi heads I have now have roller tips . stamped rockers then I can use them on my new vortecs yes just check push rods how do I do this?
Old 12-26-2012, 09:34 AM
Here is one article. Read it, then do some more research.
Setting Pushrods Length, Quick and Easy- Car Craft Magazine
Basically the path of the roller needs to stay in the center meat of the valve stem. If it stays on the edges then it will accelerate valve guide wear. If the tip rolls off the side of the stem...oops, bad news.
Here are some things that will impact the correct pushrod length from one engine to the next, or even during a rebuild...
  • core shift causing misalignment of the cam shaft bore (or align honing the cam bore)
  • base diameter of the cam shaft
  • variation in height of the lifters (brands/designs/models)
  • pre-load on the lifters
  • block deck height
  • head gasket thickness
  • cylinder head design/casting (including how well the rocker studs are aligned with the lifter bores)
  • milling the cylinder heads
  • different brands/models of rocker arms
  • valve stem height
So I hope you can see the variety of factors involved here and that you just can't blindly swap rollers. Old stamped rockers are not sensitive to pushrod length like rollers are. You must take these things into account.
Old 12-26-2012, 08:10 PM
thanks looks simple I will order comp cams push rod gauge
Old 12-26-2012, 10:01 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You can make an adjustable pushrod length checking tool, click on the image for details:
For checking the geometry, here's a short page. The general consensus of engine builders is to shoot for a narrow roller-to-valve-tip pattern, rather than a centered pattern. If you can get BOTH a narrow AND centered pattern, all the better.
Other areas of the valve train that need to be checked are here.
tbi heads ballingameover@live. Engine 3 10-18-2009 09:48 PM
TBI heads sbrooks Introduce Yourself 3 07-03-2009 09:49 AM
89 TBI heads? Nelson67Camino Engine 1 03-11-2009 01:47 AM
tbi heads 85 regal Engine 4 03-08-2003 07:25 PM
TBI AND TPI HEADS. JGEISER Engine 1 10-22-2002 08:52 PM
