TBI Heads on older motor - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-08-2005, 12:40 PM
New Member
TBI Heads on older 350 motor?
I'm having a head problem. Money's tight, so I need to make do with what I have. I have spent most of the day looking thru and searching the posts here. I have a 70's 4 bolt 350 in a 81 El Camino. Q-jet carb, headers, and dual exhaust. All I know about the motor is it's bored 10 over with a "R/V Cam." I have put in a call to the person that built the engine for more specs, to no avail. My problem is that the studs are pulling out of the heads to the point that one valve is destroyed. I can't believe the keeper is still holding it. Castings on the heads are 3973487X. I have a set of 14014416 heads with 194/150 valves and a set of 10120928 with what I read in the past were 193 valves, don't remember the exhaust size. The 416 heads are bowl hogged with 30* cutback to the valves, guide boss cut down in the ports, Z28 .500 lift springs,threaded studs and a fresh 3 angle valve job. The 928 heads are just stock plane jane heads that I did by hand a year ago, with pressed studs. I also have Edelbrock Performer intakes to fit both bolt patterns. Which heads should I use? I thank you all for your help in advance.
Last edited by exmurdoc; 07-08-2005 at 01:06 PM. Reason: Added information and spell check.
Old 07-08-2005, 05:21 PM
NAIRB's Avatar
The 416 heads are 305 castings, and will raise the compression ratio of a 350 considerably. If the heads are worked over, they can make a good stump puller in a 350, but be careful to not raise the compression ratio over 10.0:1 as this is borderline for an iron cylinder head, and can lend itself to detonation/spark knock issues.
The 487X heads are excellent flowing early open chamber designed heads, and would be my choice to use if I could afford to have them repaired. Avoid the late model, "swirl port" design heads if you can, they offer poor flow and are only good in very low RPM engines, and offer little value in a performance application.
My choice would be to keep the 487X heads if you can, and if not, use the 416's but only with a recessed head type piston to keep compression ratios down to a reasonable level.
bored motor heads Needaknowwhatiam Engine 1 10-29-2003 05:06 PM
Wut set of heads for my set up? Trav Engine 2 10-15-2003 09:45 PM
TBI Swirl Port Heads 1BDMNTY Engine 2 06-17-2003 08:52 PM
tbi heads 85 regal Engine 4 03-08-2003 07:25 PM
TPI on older motor?? 70MonteTPI Engine 7 04-20-2002 03:32 AM
