Tbi from junkyard - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-31-2011, 09:41 PM
Wiki Edits: 31
Chevy started w/ TBI in '87. 1 year only for the '73-'87 series of trucks
'87 has no transmission controls, a few other things that make it easier to swap from what I'v heard... any '87-'95 truck with a 700R4 or 5spd will work with any non computer controlled transmission.. '87 might be non- EGR but I'm not certin. I'v never worked on a '87 TBI.. only mid 90's. so I'm not sure
I was researching putting a factory TBI into my hotrod, and found that it will work well. however, it will create a tame engine. it needs the right cam because of the MAP sensor. generaly good for about 300 hp.. the easy solution was an aftermarket controller, like a FAST or Megasquirt setup, to get rid of the cam requirements, because it can tune a hotter cam. then the only limiting factor is the 2bbl TBI, but the Holley/454 TBI flows 670 CFM which is enough for a Mild 350
  #17 (permalink)
Old 02-01-2011, 06:20 PM
Check your spark plug gaps
How about some links for the fast and megasquirt controller. I am a tbi fan and am always trying to do a little more with it and push it to the limit. I am just starting to get into the tuning and have all of the stuff to do it now, now it is just months of research.
  #18 (permalink)
Old 02-02-2011, 12:08 AM
Wiki Edits: 31
http://www.fuelairspark.com
http://www.megasquirt.info/
  #19 (permalink)
Old 02-02-2011, 10:29 PM
Last journal entry: Got it running
If it were me I would either go carb or go for a tpi set up. I wouldn't go half way.
  #20 (permalink)
Old 02-02-2011, 11:30 PM
Race The Truck
Last journal entry: Son's Truck
Originally Posted by crussell85
you still need the factory ecm though
These sites are where you need to go to learn everything you need to know! The first one is a custom computer that you can tune with out burning chips if you want the best! Second site is where you will learn what you need for a truck build computer options and so on! Third site is everything you need to learn about tuning/performance!
Craig
JunkYard TBI projectjohn Engine 2 04-13-2006 12:57 PM
Junkyard HEI Thom Laybourne Engine 2 09-08-2004 03:46 PM
junkyard dog ! oldsgeek Engine 7 09-07-2004 12:05 PM
Junkyard Dog NAIRB Engine 14 01-05-2004 01:12 AM
Junkyard I came across crshrmn3 Hotrodders' Lounge 1 12-19-2002 01:11 AM
