TBI Limits on Performance - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2008, 06:14 AM
Greetings to the experienced. My question is this: How much can you modify an engine when using a Throttle Body Injection (TBI) with a Manifold Absolute Pressure (MAP) sensored ECM?
Anyone changed cams and compression and NOT had to reprogram the prom?
Can the prom be reprogrammed to account for the increased cam size and compression?
Thanks for all your help.
Old 02-09-2008, 07:25 AM
47chevy's Avatar
Last journal entry: Here is the car after paint
I just built a 350 TBI for a 1992 Chevy 4X4 truck. Installed a 94 Camaro LT1 camshaft, 97 5.7 vortec heads, GM Performance parts TBI intake for vortec heads and egr, had the tbi bored out to 50mm and installed a walbro fuel pump and special spring in the fuel regulator for 17psi to the injectors. Brian at tbi chips made me a special chip, is excellent to work with. It runs very well. Major increase over stock about 100 hp it idles just like stock you would never know whats under the hood.
If you are thinking about doing something like this contact Brian and he can help you also visit his web site at www.tbichips.com He has lots of info there.
TBI assistance needed jack kelley Engine 5 05-24-2006 10:11 AM
5L TBI to 5.7 TBI swap headscratch Gearhead forever Engine 2 06-07-2005 11:24 AM
305 tbi into an older 350? help... NOSBOSS Engine 2 03-23-2004 09:45 PM
Auto Performance Business Venture Plan Opinions(long read) TurboS10 Hotrodders' Lounge 17 12-01-2003 09:33 PM
350 GM Goodwrench Caprice engine in 3rd Gen TBI F-Body? wrmason3 Engine 2 09-14-2002 07:01 PM
