on the tbi motors.. can you mod it to use the old HEI distributor ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-23-2006, 09:12 PM
I have heard this can be done but thought I would ask.. I can't stand the TBI distributor and thought the old school one would work better./. Worth a shot
Old 12-23-2006, 09:18 PM
DoubleVision's Avatar
THe Distributor in the TBI engines is a HEI, it`s just made smaller for more clearence. The computer controlled unit works nicely on mine. the computer wouldn`t work very well without the timing control, since it`s related to the fuel management.
Old 12-24-2006, 06:57 AM
Hippie's Avatar
Last journal entry: HEI comparison.
The early TBI's and TPI's used a standard size body HEI. I have an '85 TPI unit with the large body HEI. It should be pretty easy to find the correct distributor, much less hassle than trying to convert one.
Old 12-24-2006, 04:14 PM
If you're referring to the first style of HEI's, used from the mid 70's to the early 80's (all with vacuum advance), probably not real easy to integrate...unless you're able to do some real eprom massaging and intergarte a tach signal to the ECM.
The HEI's frm 82 or so on up, didn't have the vacuum advance, and timing advance was controlled in the EPROM.
Mallory Unilite vs. HEI distributor 7dcrzr Engine 19 05-23-2007 06:14 PM
convert 1989 TBI to HEI??? boneyard Buick Engine 0 10-30-2006 01:26 AM
hei distributor hookup help meev182 Electrical 11 07-07-2006 03:35 PM
hei distributor venom Engine 7 06-17-2005 04:37 AM
TBI distributor advanceing punk1c5040 Electrical 5 01-19-2004 07:02 PM
