tbi pickup to get gen. 1 block - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-10-2009, 06:21 PM
i have a 90 c2500 w/ 350 tbi and wanted to swap in a built gen. 1 small block and leave the computer and tbi. plans are to use an adapter for tbi to carb intake. but i was not sure if the electronic distributor would fit right in the older style intake. i was planning on using a performer intake. have heard that some mid 80's camaro's have the distributor i am looking for? then was also not sure if i needed do change anything with the prom in the pcm. the donor block is out of a late 70's truck that has been rebuilt for an old 4x4 blazer i used for off-roading. it has a decent cam having about .490 lift and made for low end power (comp cams extreme 4x4 series) .100 dome pistons and world product 76 cc cast iron s/r torquer heads. compression is around 10-11 to 1. i just have a feeling the stock programming will not keep it running right. i do not have to worry about emissions where i am but would like to keep the engine light off if at all possible. i know this is alot but can anyone help?
Old 02-19-2009, 08:20 PM
Check your spark plug gaps
you have your work cut out for you man. What about your egr valve. Buy a an edelbrock performer t.b.i intake. That will accept your egr and you will have a place to mount your coil. You will have to oval the 4 center holes on the intake to make the bolts fit but the gasket will seal fine. That is some high compression for pump gas especially with iron heads. I hope you have a good cooling system. Iron heads you should go no higher than 10.0:1. I would suggest either aluminum heads or flat top pistons with 2 valve reliefs. You are in some luck though. The tbi will be a nice upgrade from a carburator just not a stock 350 tbi. You need like a 670cfm tbi with a 90gpm or gph whichever it is. The distributor that you have should work just fine. You will need to change your stock programming. That should be the last thing you do though. Get everything tuned in as close as you can then get a mail order chip. If you change the chip you could also do away with the egr valve it will just cost you some fuel mileage. I am a fan of the efr myself. I have a 383 stroker and I will not give it up. Unless you build the snot out of a motor and don't have the vacuum to run the egr valve try to keep it. Hope this helps.
Old 02-20-2009, 06:28 AM
the distributor will fit fine. the TBI engine is also a gen 1 engine
Old 02-20-2009, 11:49 AM
Race The Truck
Last journal entry: Son's Truck
Well the problem is TBI controls!
If the cam is not a TBI cam you will never get it to run right. Then you will need to have a custom chip burnt and so on.
Last the best option is a replacement injection Manifold from Edelbrock. It is a direct replacement to the TBI and for 900.00 buck a real good deal.
Check out Summit they have It. Also I talked to Edelbrock tech line. So if you go for the Holley tbi and manifold its 800.00 plug bucks tbi spacer and so on.
Injection is a better way to go.
Craig
Old 02-20-2009, 07:50 PM
i appreciate the help, i have been doing a lot of searching through the bulletin board and have found lots of useful tips. did not know after-market intake was available for the swap. also have been looking into prom burning and have found kits through moates.com but am a little hesitant to try programming with no experience in it. i think i will just swap the cam, chip, intake and hope for the best. crussell85 where did you get your chip, and i have found some big block throttle bodies that have been modified to flow more. those should bolt up right?
Old 02-20-2009, 09:56 PM
i don't have a chip yet i am still in the process of building but it will come eventually. there are companys out there for the chip you will just have to find one that sounds good. I personally haven't looked yet. a 454 throttle body will be ok i guess but the holley i think would be a better choice, but if you have a 454 slap it on. You will also have to do something with the fuel pressure regulator to allow the new fuel pump to pump that much pressure without shutting the pump off. research research research i can't stress that word enough man. it will take longer with all of the research but it is well worth it.
Need some help with 1986 GM 305, TBI or Carbed??? dieselcruiserhead Engine 8 12-19-2010 07:32 AM
Big block questions, help please??? 67 sleeper Engine 20 05-15-2007 04:24 PM
What heads for a Gen 2 383? mattson70 Engine 0 02-28-2007 11:12 AM
Small Block Vs. Big Block bfrett123 Engine 3 10-14-2004 05:27 PM
350 GM Goodwrench Caprice engine in 3rd Gen TBI F-Body? wrmason3 Engine 2 09-14-2002 07:01 PM
