tbi problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-05-2006, 08:32 PM
tbi problems
just took ownership of 55 pu with 95 tbi motor and 700r trans. heres what i did
replaced elec pump no prob...then had great idea!! cut in a secret switch
so as to have a littel peace o mind. cut and spliced power wire from pump
relay to pump.now i have no power going to relay at all!! opps! put the wire back but still nada..might have grounded it or somthing worse..ant ideas on what might have broke? all fuses good and it has painless wiring for motor and truck has newer fuse box and wiring thanx...
Old 05-08-2006, 11:47 AM
DaSouthWon's Avatar
I put up the tools against$300
pull the relay and reinstall it, it may be stuck open. your switch may also be grounding it out, look where you pass the wire through the firewall and make sure you haven't rubbed the insulation off of the wire.
Old 05-09-2006, 06:23 AM
Contact Painless tech through their web site at painlessperformance.com if you're still having problems. They will be glad to help out.
92' chev 350 tbi problems 53fordguy Engine 15 01-18-2006 01:33 PM
TPS problems with TBI MartyMart9@aol.com Engine 13 02-12-2005 10:04 PM
TBI vortec problems 11secmudtrk Engine 3 12-14-2004 10:20 PM
TBI Starting problems punk1c5040 Electrical 6 10-29-2004 07:20 PM
91 camaro tbi problems knagel Hotrodders' Lounge 0 05-21-2004 09:00 AM
