TBI rev limiter - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-07-2008, 08:45 PM
TBI rev limiter
I race(oval track) a 1993 S-10p/u with a 4.3l TBI/automatic/3.42rear......
At tracks with longer straightaways the rev limiter cuts out the ignition and injector pulses..................
Is there anything out there, reprogrammed prom, ECM, etc., that will get rid of or raise the rev limiter to a higher rpm...................
Thanks .................UNCLE PETEY
Old 02-07-2008, 09:24 PM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
I used a hypertech power programmer to change the rev limiter and speed governer on my 2002 chevy pickup.
If your s10 has an OBDII port there should be plenty of options
Old 02-07-2008, 09:37 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
The rev limiter is usually trigered by the TPS at wide open throttle. Try modifing modifing that to give it more adjustment, so when you are at wide open throttle it will think you still have more throttle left. That could be as little as .010-.020. Keep in mind that will effect your idle, so try to keep it as close as you can without raising your idle speed too high.
Old 02-08-2008, 02:17 PM
It's in the chip programming on these OBD-1 systems, it takes a new chip see these guys:
http://www.fastchip.com/
http://www.tbichips.com/
http://www.hypertech-inc.com/
http://www.superchips.com/
http://www.tpis.com/
Bogie
ford rev limiter carsronnie Engine 1 07-26-2005 08:56 PM
REV Limiter? street rodder 1937 Engine 2 03-31-2005 07:42 PM
MSD 6AL rev limiter strokercuda Electrical 1 12-01-2004 01:08 PM
Rev Limiter and CD ignition setups. Croz Electrical 0 04-01-2004 09:33 PM
Rev limiter CombatWombat Engine 2 03-27-2003 06:50 PM
