tbi trouble - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2009, 05:29 PM
tbi trouble
I have an 87 chevy R-10. 350-350 combo. Engine has tbi on it. I have recently been experiencing some trouble with the engine running properly. It runs fine when the motor is cold but when the motor gets hot it wont want to idle in gear. It will slow down and want to die unless i brake torque it(which isnt the safest thing to do). I have replaced the idle air motor and the fuel filter is fairly new. I have also tested the throttle position sensor and it tests good and I have tested for vacuum and all is well there. Any idea's would be greatly appreciated.
Old 10-17-2009, 06:27 PM
DoubleVision's Avatar
Have you checked the coolant tempature sensor?
Old 10-17-2009, 11:46 PM
no that is one thing that i have yet to check. any ideas on how to do so?
Old 10-18-2009, 11:09 PM
it's a pita to do, but check your fuel pressure. tbi's will actually run with less than 1 psi, but require at least 9psi to run right. 13- 14 lbs to run really good. had the same problem with mine.
Need some help with 1986 GM 305, TBI or Carbed??? dieselcruiserhead Engine 8 12-19-2010 07:32 AM
TBI assistance needed jack kelley Engine 5 05-24-2006 10:11 AM
Timing Trouble 350 TBI Raul_Chile Electrical 6 03-15-2005 08:57 PM
Idle trouble 1990 TBI ryan_itt Engine 4 12-17-2004 12:56 AM
TBI Questions on a 93' Chevy FS 350 IWANTMOREHP Engine 1 01-04-2004 01:42 PM
