Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - TC lock up idea. Would this work?
Old 08-17-2012, 10:11 AM
JohnTN JohnTN is offline
At a minimum, run the power through the brake switch Normally On connection so that the TCC disengages when you hit the brake.
There are other switches you can put in series in the power line to make TCC lockup more driver friendly such as: vacuum switch and vacuum or timer delay switch.
John
