Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - TC lock up idea. Would this work?
Old 08-19-2012, 07:05 AM
SSedan64's Avatar
SSedan64 SSedan64 is offline
Originally Posted by gsoleski View Post
alright sounds good. I've heard you need to connect A to a fused ignition source? How can I do that? Splice a wire to an ignition wire and put an inline fuse on it between the splice and the trans? Or an open spot in the fuse box?
84/Z-28 should have the 4-Terminal Brake switch that's already fused. Connect to that. The Terminals needed will cut 12V+ when Pedal is depressed. Install a Toggle switch inline for around town driving if wanted to disengage TCC Lockup manually.
http://www.hughesperformance.com/pdfs/HP700-R4.pdf
