TCC error code P1860 in 4L60E tranny - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-29-2005, 03:34 PM
New Member
The blazer has 77000 miles on it. And we are the third owners. We've had it since 1999 (its a 1996). The tranny fluid was a little dark and did have a slight burned smell to it the first time I took it down a couple of months ago. When we got back into it again last week. The fluid was good with only a hint of burned smell (replaced 6 quarts of fluid with the service the first time). The blazer is driven usually less than 10 miles per day, and used rarely as a tow vehicle. And when towing, its a light load, less than 2000 pounds. The code came up after the radiator went out on us on a ~350 mile trip towing a light trailer (~1200-1500 pounds) in march.
I'm not sure what else to add. I guess the next step is to find a good tranny shop. Any suggestions? AAMCO or MR Transmission any good, or do I need to find a private shop?
  #17 (permalink)
Old 07-30-2005, 02:18 PM
Hi, I was the guy that did the work on Pilothawks transmission. I have done the sonnax repair at work without fail.
On Ph's trans it solved the problem until it reached TC lock up speeds in the 70 MPH range and then it set the hard code again. I installed the sonnax tcc reg valve kit ( the bore was worn) and the transgo kit for the other 4l60e issues. The only thing that I didn't do on his trans is replace the VB spacer plate (which was worn and I attempted to repair) my thinking is that it is possible that the TC check bal is not seating in the plate well at all and is quite possibly letting a leakage occur and allowing a slip. while it may be possible that a seal has gone south, there wasnt any serious particle accumilation in the trans pan that would suggest a seal or friction plate failure.
Scott
Originally Posted by Crosley
Then there is a problem some where else in the PWM system or the converter has a cut seal internally.
Replacing the VB may not fix the problem either.
What is the mileage and history of this tranny?
  #18 (permalink)
Old 07-30-2005, 06:34 PM
airworld2's Avatar
4l60e
you need scan tool to see the data stream, tcc slip
as I stated before you can over ride tcc to see if it working no guess work involved. my advise would be small shop rather than the ones you asked about, never seen spacer plate cause this trouble plate always has one ck ball hole always wore out replace it or repair it or install large ck ball
airworld2
  #19 (permalink)
Old 08-09-2005, 04:22 PM
New Member
Its fixed!
Thanks for all the help guys. It turns out that the TC was smoked! Clutch was gone in it and it got hot enough to turn the converter a nice purple color.
Here are some pics.
The shop I had the work done at only charged me 375 bucks to change the converter, the pump valve, and change the oil. I Now have a total of about $525 in the repairs that I have done/had done. Much better than the 1700 that Mr Goodwrench (Mr Crookwrench) wanted to charge me.
ID:	6331   Click image for larger version
ID:	6332   Click image for larger version
  #20 (permalink)
Old 10-18-2005, 03:26 PM
me too
i am having the same kind of problems with my 4l60e. i havent been able to scan the codes yet but i think it is probably the same thing. i get the discolored and slightly burnt smelling tranny fluid. do you guys think its the torque converter too? I thought that might be what it was but im not sure. i figured i would do a little research and this is where im at so any little bit could help. thanks.
2005 4L60E tranny Crosley Transmission - Rearend 8 05-18-2008 02:51 PM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 01:48 PM
4L60E tranny HELP huntingonedown Transmission - Rearend 2 05-09-2004 11:57 PM
88 AOD tranny problems rflud Transmission - Rearend 9 02-17-2003 05:53 PM
can i use a 4L60E tranny & computer with a carb. engine r50max Transmission - Rearend 2 12-14-2002 08:44 AM
