TCI IFS install - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-21-2011, 10:55 AM
TCI IFS install
Just installed an ifs for first time and am not certain if I have enough adjustment in t-bolts. Did everything according to instructions, measurements are right on,but t-bolts are at out side of slots and discs sit at 0 with no weight.also not clear on how sway bar installs,no paperwork.Any help or pictures would be much appreciated.
Old 11-22-2011, 02:48 PM
slow4dr's Avatar
Sway bar mounting will depend on the vehicle application. The smaller bars(pretty much all the pre 60's cars) 3/4" & 7/8" mount behind the crossmember via two aluminum "pillow blocks". The large 1" & 1.125" bars used on the muscle car applications mount up front via saddle mounts.
Don't worry too much about the alignment slots at this time. The springs need to settle before the alignment can be done properly. Or atleast if you align it now you will be redoing it once the springs settle.
-J
Old 11-22-2011, 03:16 PM
Irelands child's Avatar
The TCI website has the instructions. You do have to dig in to find them as it is not a friendly site.
It does all fit - this is with different springs and better sway bar links, but is a TCI on a Model A:
Irelands child
Old 11-23-2011, 11:39 AM
55 ford p/u ifs concerns
Thanks for the info.New at this and the old straight axle on the shop floor has been looking pretty good lately.I'm waiting on wheels to set it on the floor get the cab set down,302 & c-4 in for some weight.I went with 2" drop TCI ifs and would like truck to sit close to level.Somebody suggested Ford ranger single leaf??? on a 9" Trying to keep the $$ down so not to freak the wife out over a re-mortgage.ha ha Have line on 9" disc rearend out of a lincoln 58 1/2" I think. Front measures 60 1/2". Can this work with offset wheels. I'll try to get some pics on when I can find a kid to show me around this machine.
Old 11-23-2011, 11:59 AM
-J
Bought the TCI for 53-56 Ford P/U it's got pillow blocks that fit on the back.Just not to sure how not to get the cart before the horse.Put a-arms ,springs/shocks and spindles together,ended up denting shocks.I'm waiting for some 5 x41/2 wheels so I can get it back on the floor add some weight and see what happens then. Thanks for the input, Joe
new cam install phanline6.6 Engine 13 03-10-2010 09:08 AM
28-34 4 bar install Tonythefish Suspension - Brakes - Steering 11 11-09-2006 10:12 AM
SBC install oldrodder43 Engine 2 09-08-2006 11:36 AM
How to install NOS? smokin Engine 0 10-31-2003 03:34 PM
350 tpi install underwaterworker Engine 1 02-25-2003 11:56 AM
