TCI Mustang, 36 Ford - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-07-2011, 05:36 PM
joeford's Avatar
36 Dream
My project was toasted in a fire just before going to the paint booth. I'm in the rebuild process but have run in to a problem. All rubber in front suspension melted away. TCI will not sell rubber bushings by themselves and will only sell with complete new control arms. Also unable or unwilling to advise who their supplier is...My control arms are fine as the fire was not hot enough to threaten metal. To make my point, the body did not even warp and that would be the first to go. I thought I had solved the problem with bushings I ordered from Energy Suspension. I now find that they fit in only two of the three ways required. So, my question is.....by chance is there anyone out there who has a TCI chassis for a 35-40 Ford with the Mustang front end and who has had to replace the bushings? If so, then do you recall where you got them and do you have the part number?
Old 07-07-2011, 05:52 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Sorry about you bad luck, i found this on another site thought you might want to read this. TCI chassis http://www.classicshoptalk.com/steer...all-apart.html .in case the link don't work here is what they did for this guy. I bought a TCI front end with a power rack. The rubber mounting bushings started to fall apart within months and really look like heck after a year. I bought a second front end and these bushings are now polyurethane.
{I just called TCI and they are SENDING ME A SET OF POLY BUSHINGS at no charge. }
You know they are bound to have replacement bushings for these parts. JMO
Cole
Old 07-08-2011, 11:06 AM
joeford's Avatar
36 Dream
One would think....
I find this interesting and I do agree that one would think they have bushings in stock. I've had trouble getting a return call. So, I starting working through the Yogis where I purchased the chassis. They told Yogis that since I bought the chassis six years ago they don't carry the bushing anymore....then they told them I could buy them but I'd have to buy the control arms as well.....because that was they way they bought them as a complete unit....And again, will not even provide the OEM. I find this all very bizarre. Anyone out there got contacts at TCI....perhaps you could get them to reconsider.
ps...Just fyi...Yogis has been great in trying to assist, but unfortunately have had no better luck than I with TCI.
Old 07-08-2011, 12:12 PM
Arrowhead's Avatar
EFI Rules and Carbs Drool
Last wiki edit: The FREE T Bucket plans
Last journal entry: Sold Everything for a new project
Wiki Edits: 5
Can you measure the dimensions of the bushings and source them from the aftermaket? I know they are melted, but you should be able to get an inside dia, outside dia and a length and find them somewhere.
Old 07-09-2011, 02:04 PM
joeford's Avatar
36 Dream
Tried it...
If bad could not be worse.....I measured with a micro and picked up on some from Energy Suspension that were close enough to make we want to yell Halleluha!.....Then the order came in and I learned what a difference 1/32" can make in fit versus wobble. Anybody need some ES 9.1111? I have 8pair in the box. Lesson #2....Don't trust a cheap micrometer... $30 made in China...
ps....I've found a couple of references in cyber to some ES part numbers. Problem is they are not in the catalog. I'm trying to contact them by email to verify.....Hopefully they have just changed the part number and not gone out of production.
Again....anybody out there got information, it will be appreciated.... :
Old 07-11-2011, 01:02 PM
slow4dr's Avatar
Energy Suspension is the supplier.
I sent an e-mail to the sales department to make sure they are clear that the bushings are in fact available separately.
FWIW: I order these in anywhere from 2000-5000 quantites so there are plenty in stock at any given time for replacement orders like this.
Sorry for the confusion
Uppers = 2652.01
Lowers = 2618.06
-J
Old 07-12-2011, 08:30 PM
joeford's Avatar
36 Dream
Slow4dr
So, u sellum?
Old 08-29-2011, 09:37 PM
joeford's Avatar
36 Dream
getrdun
Thanks slwr4dr...u gotrdun
1948 ford f-1, 1981 ford f-150, mustang ll pile up derrick_500 Suspension - Brakes - Steering 6 09-09-2008 02:17 AM
1989 Ford Mustang and 87 Ford Bronco fordman83 Introduce Yourself 4 03-23-2007 11:54 PM
ford f100 & newer ford mustang photoshops lowROLLERchevy Hot Rod Art 0 02-06-2006 04:52 PM
need help ford mustang II brian caruana Suspension - Brakes - Steering 6 12-29-2005 08:23 PM
Ford 460 into a Mustang thiems Engine 1 09-24-2003 06:40 PM
