Turn plates are an alignment tool used to indicate the angle you have the wheels turned to. You set the front wheels on the turn plates and the rear wheels on a spacer the same thickness as the plates. Center your steering, zero the turn plates.....Now you can check/adjust caster....
They look like
THIS
