Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - TCI mustang II IFS caster adjustment
Old 07-19-2008, 01:37 PM
ceh383's Avatar
ceh383 ceh383 is offline
'51 Chevy 3100
Alright, I got the turn plates and set everything up. I took initial caster readings then tried to adjust it with the nuts on the ends of the cross shaft.....I could get no movement of the a-arm in relation to the cross shaft. My front end is from TCI and I do not see this as a way to adjust caster, not even a fine adjustment. So the person at TCI who told you to adjust this way must be smoking crack.....
