TCI rotors - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-19-2005, 09:33 AM
TCI rotors
I just got the front end installed on my truck last week and when I went to put some wheels on I coulnd't get a lug nut to fit. After going to the local auto parts store and getting a variety of nuts I discovered that the lugs are metric. I'm probably just ignorant but is this the case on all new TCI rotors? Thanks.
barry
Old 09-19-2005, 10:16 AM
If you have GM pattern rotors.......GM went to metric studs about 20 years ago.....so all the 20 year old UP GM rotors will have metric threads.
I bought a TCI Stage III chassis for a 40 Ford ( with Ford pattern rotors ) recently and it had 1/2 20 SAE threads on the rotors.....
Old 09-19-2005, 11:18 AM
Thanks Deuce....like I said...I'm ignorant. Everything I work on is mid 70's and older. This is just something I will have to stick in the ol' memory bank. Thanks again.
barry
Old 09-19-2005, 12:07 PM
You can press the metric stuff out..and press the good ole SAE stuff in....and I would IF the rear end is the same pattern and SAE threads.
The metric lug nuts also have a different angle on the shoulder of the nut.....so they do not shoulder up real good on the older wheels.
Old 09-19-2005, 07:21 PM
tci rotors
I ran in to the same problem. Fronts are metric, rears are US. I can't for the life of me imagine why TCI doesn't put the same size on the front and rear. I had a 50/50 in selecting chevy or ford pattern- not only the above problem, but when you request chevy pattern you get smaller rotors too! I paid them nearly $8k for my chassis, don't feel like I got my $ worth. Have other problems they could fix, if they wanted to, as well. Next frame for me will not be TCI. Bill
Warped Rotors Fast Orange Suspension - Brakes - Steering 23 08-16-2005 09:59 AM
Need help finding dics rotors... bg Suspension - Brakes - Steering 10 05-13-2005 11:47 PM
TCI Pro Super Kit Houman SS '70 Transmission - Rearend 0 04-18-2005 04:29 PM
blank rotors Mr Miyagi Suspension - Brakes - Steering 1 03-13-2005 08:28 PM
Problems bolting TCI Converter to TCI Flexplate Ghetto Jet Transmission - Rearend 2 06-19-2004 08:48 PM
