Tci shifter mount - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-09-2014, 11:37 AM
Last journal entry: FIRE WALL AND FRONT END
Tci shifter mount
Hi guys i need to mount my shifter on a curved trans tunnel does anyone have any pics of a good mount ...thanks
Old 03-09-2014, 12:05 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
what design shifter?
My ProStick is on custom pedestal mount I built so I can reach the shifter easier.
The Following User Says Thank You to Crosley For This Useful Post:
THE FAT CONTROLLER (03-10-2014)
Old 03-09-2014, 01:10 PM
Irelands child's Avatar
If it's their cable shifter, why not look at your tunnel then fab something up as Crosley did with his cable shifter. If you want it to be fancy - wide open for whatever you design. Rudimentary - bolt it to the floor. Heck, even the Lokar rod shifters can be 'fancied' up such as what I did:
A block of wood, a couple pieces of aluminum, some vinyl sewn into boots and all screwed to the floor with SS fasteners and it's done.
Dave W
Irelands child
The Following User Says Thank You to Irelands child For This Useful Post:
AutoGear (03-14-2014)
TH 350 Cable Shifter Mount Holes 91CamaroDude Transmission - Rearend 3 09-24-2012 07:21 PM
700R4 shifter mount Infinite Monkeys Transmission - Rearend 2 01-02-2012 04:58 PM
shifter tower, shifter rail and shift fork diagram needed! Chris Kemp Transmission - Rearend 0 02-12-2009 05:59 PM
283 front mount convert to side mount jomil Engine 10 01-19-2007 09:09 AM
Problems bolting TCI Converter to TCI Flexplate Ghetto Jet Transmission - Rearend 2 06-19-2004 08:48 PM
