TCI Streetfighter II Tranny Leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-12-2011, 07:55 PM
I am fairly new to the hot rod community. I purchased my first rat rod about six months ago. It is a 1959 Apache with a 383 stroker and a TCI Streetfighter II 3 speed automatic tranny. I have a leak that is coming from above the pan on the front corner on the passenger side. Thanks for any help.
Old 06-12-2011, 07:58 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
It's probably the dipstick tube the o-ring. JMO
Or it can be where the cable hooks into the trans on that side also. JMO
Cole
Old 06-12-2011, 08:06 PM
eloc431962's Avatar
Wiki Edits: 37
And welcome to the site.
Cole
Old 06-12-2011, 11:17 PM
leak
if you could tell us what type trans it is we might be able to help
Old 06-13-2011, 07:23 AM
Irelands child's Avatar
Welcome to the site!!!
Yep, I agree, dipstick tube seal. I had to replace my $$$ Lokar with a $$ Hughes to get mine to stop, also a TCI trans.
New seal, new pan gasket and possibly some sealing washer under flange head bolts should stop the drip. Also, that TCI pan might not have a flat bolt flange as I also found
Dave W
Irelands child
tranny leak 1966bowtie Transmission - Rearend 7 10-11-2007 09:27 AM
TCI Streetfighter rated HP use Fil Transmission - Rearend 6 08-29-2004 10:07 AM
Tranny leak ThrouHerEyes Transmission - Rearend 1 09-02-2003 11:37 AM
tci streetfighter tranny snnokmaster Transmission - Rearend 3 08-21-2003 05:16 AM
tranny leak bubb rubb Transmission - Rearend 15 05-15-2003 03:17 AM
