Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - tcp global restoration shop grays
Old 09-06-2012, 09:15 AM
cyclopsblown34's Avatar
cyclopsblown34 cyclopsblown34 is offline
Colorsanding painter
Just go to your local paint store for materials, you'll be supporting a local business and have local support when you have issues. BC/CC is actually cheaper than SS urethane because you're spraying the base to achieve coverage and then clearing to achieve your shine. Clear is cheaper per gallon than SS Urethane. Maybe check a Slo Reilly for a factory pack single stage, it should include, color, reducer and activator. It'll be Nason but you can actually see what the color should look like. If you go BC/CC and want to buy local and be fairly cheap, use Nason or Omni Basecoat and Nason 497-00 clear (3:1) mix. I've found a clear I really like at Southern Polyurethanes, it's their Universal clear and I prefer it over all other clear. I have to order it in but it's worth it for the end result, it's about 250.00 for two gallons of sprayable clear.
